Old 02-26-2005, 09:38 AM
SublimeAndy SublimeAndy is offline
Default quick question needs quick answer
right now i have 4 vocal tracks and i want to bus them all to the same track, my question is, two of them are panned, will this panning be picked up on in the track i bus them all to? and shoudl it be a mono or stereo track? someone help quick, i'm mixing right now.
Old 02-26-2005, 09:47 AM
spkguitar's Avatar
Default Re: quick question needs quick answer
If you bus to a stereo track everything should be fine.
Old 02-26-2005, 10:30 AM
thanks!
Old 02-26-2005, 12:22 PM
one more thing, should i delete all the old tracks once i have them all on the same track?
Old 02-26-2005, 12:29 PM
lemix's Avatar
lemix lemix is offline
SublimeAndy ,
By "bussing" them the original tracks are still being used and routed internally ( in the mixer ).
Only BTD will create a new set of tracks ! Then...you could "remove" the originals from the session.
I would however still keep them on the disk...just in case .
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 02-26-2005, 01:50 PM
JMS40 JMS40 is offline
Bus them to a stereo Audio track and record the pass.
No need to BTD.
You can delete the originals after that if you're absolutely sure you won't need them again.
Old 02-26-2005, 02:13 PM
wolfskin wolfskin is offline
Yes, as stated above. BUT, why delete the old tracks? Disk space is cheap. To save the voiceable 32 tracks, simply disable the original tracks. Then you can always revert to them should you need them...
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 02-27-2005, 09:36 AM
ok, now's where i ask.... what's BTD? if the answer is blatantly obvious i apologize for my pro tools ignorance.
Old 02-27-2005, 09:44 AM
Bastiaan Bastiaan is offline
BTD is Bounce To Disc.
It's in the File-menu and choosing that will play the entire sesison (or a selection) and record (or bounce) that to disc using the parameters you set.
What's that?
- That's the machine that goes "pling".
Bastiaan
Stupid question, but need answer quick. HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-10-2010 07:13 AM
need quick answer for simple question richsorr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-16-2004 07:14 PM
Quick Question - Easy Answer... jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-23-2004 02:36 AM
Newbie Quick Question - Y or N Answer - Help... jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-10-2003 09:46 PM
Newbie with a quick question - Y or N Answer? jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-10-2003 06:19 PM
