Old 01-23-2021, 06:58 PM
Tom Polce Tom Polce is offline
Default MacBookPro&ProTools - 96k w/Headphone Jack
I've got a MacBookPro - 2017 13". I had to edit a 96k sesh on the laptop and it won't do it. Won't play anything at 96k. If I play a 96k file via Quicktime - No Prob. If I try to create a 96k sesh in Pro Tools with headphones plugged into the jack - it won't even give me the option to create a 96k session. Oddly - The Laptop WILL let me create and play a 96k ProTools session if I do not have anything plugged into the headphone jack and it will play through the onboard speakers without issue. Fricken lame. I'm pretty sure I was able to do this on earlier macbook pros. Anywho - the fix was relatively inexpensive, though there are much larger and more expensive devices to make it work. I did it with this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thought I'd pass on the info.
-t
Old 01-23-2021, 07:23 PM
Default Re: MacBookPro&ProTools - 96k w/Headphone Jack
Your MBP with has a separate headphone output device, it is likely defaulting to 44.1 kHz. You should try setting it to 96kHz in Audio/Midi Setup.
Make sure you have no other software grabbing that headphone output when it appears.
Old 10-09-2023, 06:09 AM
midnightrambler midnightrambler is offline
For anyone else who comes across this thread - I’m editing “on the run” and didn’t bring my sound card and have discovered this 96k limitation, plus I couldn’t get the output to switch to 96k for love nor money. But Loopback has proven to be a godsend.
No sound through headphone jack jpconques Windows 4 07-06-2018 04:24 PM
MBOX Pro headphone jack B CowboyNeal FireWire & USB Audio Interfaces (Mac) 1 02-13-2017 08:23 PM
ProTools SE has disabled MacBook headphone jack? acvdmlac Pro Tools SE and Essential (Mac) 0 07-07-2012 04:20 PM
002 Headphone Jack Not Working spinweb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-04-2012 06:49 AM
002 headphone jack tym cornell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-29-2009 09:10 AM
