SR-16 and Pro Tools (with Delta 1010-LT)
I am lost and could use your help with a midi issue. I know midi is supposed to be simple but I obviously don't get it. All I want to do is hook up my SR-16 to Pro Tools. I have the midi cables hooked up to my Delta 1010-LT. I have set up the SR-16 in Pro Tools. That's as far as I get. I get no sounds, don't know how to test it. I've spent a lot of time searching but nothing directly applies to me. I've followed endless setups from manuals and online. I do fine with all my audio gear...
Any help would be appreciated. |
Re: SR-16 and Pro Tools (with Delta 1010-LT)
Have you set up PT to send midi clock information to SR16?
(From memory:) MIDI menu: MIDI beat clock: "Enable"/check SR16. When you hit play in PT, SR16 should play its current program along with PT at PTs tempo. There might also be a "External sync" thing that you need to set on the SR16´s menus. By the way, you do have audio cables connected aswell as midi cables dont you? Midi is not audio. IHTH
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Hi Ben...figures a Norwegian would help me! (I come from the oldest Norwegian-settled town in Minnesota). Thanks for responding.
Using your advice I got the signal from PT to the SR-16, but no signal back to PT. I admit I am an idiot with MIDI but I understand that MIDI is not audio. If I am just using PT MIDI to have the SR-16 send audio to PT, why not just just hook up the SR-16 to audio and not use the PT MIDI controller? What I want to do is have a MIDI click track with a SR-16 drum kit, so that I can manipulate the tempo until it's right. Then I would probably lay it down to audio. I'm probably completely missing the boat here. |
Hook up SR16 with midi cables and audio cables into, say input 1. Make aux track, set the input to 1. Hit the pads on the sr16 to check that you have a signal. Make a midi track and write four or eight notes on it, on the note you want to "click". Quantize and edit the volume of the notes until you`re happy, then copy and paste ("repeat paste") to the rest of the track. Now you can use the bpm control in the transport window to set the tempo you want. Hope it works out.
Why dose my pro tools 7.4 refuse to run whit 2 delta 1010 cards? | Mastabeaver | Pro Tools M-Powered (Win) | 1 | 08-16-2011 11:22 AM |
Pro tools 8 and delta 1010 | adale | Pro Tools M-Powered (Win) | 6 | 01-21-2011 05:35 PM |
Pro Tools + M-Audio Delta 1010 or just 002 Rack? | wiiking | Pro Tools M-Powered (Win) | 12 | 06-23-2005 12:23 PM |
Pro tools & Delta 1010 Compatibility Yes or No | Rewind | Pro Tools TDM Systems (Win) | 1 | 11-03-2003 12:14 PM |
Delta 1010 and Pro Tools LE? | ee99ee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-08-2003 05:37 PM |
