MTC from PT to DM-3200
I have added the guide for setting up MTC to the manuals section.
Here is a small representation; DM Set-up 1. Press the Automation (2) button; this will take you to the Automation Set-up screen. 2. In the Automation Set-up screen Cursor down to MTC (USB) and press Enter 3. Press the ALT button so that it is lit then press the Midi (8) button. 4. Cursor down to USB: 3 MTC and make sure the lines within the boxes to the left are straight across. Pro Tools Set-up 1. Launch Pro Tools 2. Click on Setup in the top right of the screen then click on Peripherals. 3. Click on the Synchronization tab and click on the drop down menu under MTC Generator Port and choose Tascam DM- 3200 Port 3 or Tascam DM-4800 port 3. (On a PC these ports will show up as USB Audio Device 3) The DM3200 or DM4800 should now be receiving Midi Timecode from Pro Tools. Good Luck...............Bottomend |
Problems: HUI with DM-3200!!! | mertenaudio | Pro Tools M-Powered (Win) | 0 | 01-21-2009 05:47 AM |
Tascam DM-3200 | Craiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-03-2006 07:35 PM |
Tascam DM-3200 | fasttraxx | Pro Tools TDM Systems (Mac) | 0 | 06-02-2006 05:04 PM |
PTLE with dm 3200 | djhead1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-23-2005 11:13 AM |
AMD XP 3200+??? | Pulque | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-24-2003 10:24 PM |
