Old 04-22-2013, 01:00 AM
sivert sivert is offline
Default Edit/score window doesn't follow cursor?!?
Since I installed PT10 the edit (and score) windows has always been static and I have to scroll manually to se what is played. I have checked the After playback option in Options, Edit window Scrolling.
This is so annoying and I just don't understand why, is this a bug?
__________________________________________________ _______
SiSoftware Sandra
ID
Host Name : Sivert-Dator
Workgroup : WORKGROUP
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS P6T DELUXE
Serial Number : MS1C8CB********
BIOS : AMI (OEM) 1102 12/18/2008
Total Memory : 24GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C 8T 2.67GHz, 2.68GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1366
Chipset
Memory Controller : ASUS X58 I/O Hub 2x 3.22GHz (6.43GHz)
Memory Controller : Intel Core Desktop (Bloomfield) UnCore 2x 3.22GHz (6.43GHz), 3x 8GB DIMM DDR3 1.34GHz 192-bit
Memory Module(s)
Memory Module : Kingston 99U5458-005A01LF 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Kingston 99U5403-034A00LF 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : Philips 237EQ (1920x1080, 23.1")
Monitor/Panel : SHP SHARP HDMI
(1920x1080, 64.4")
Video Adapter : AMD Radeon HD 6450 (SM5.0 650MHz, 2GB DDR3 1.2GHz 64-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : Caicos (160SP 2C 650MHz, 2GB)
Compute Shader Processor : AMD Radeon HD 6450 (650MHz, 2GB DDR3 1.2GHz 64-bit)
Storage Devices
WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", 32MB Cache) : 932GB (F:)
SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (C:)
WDC WD30EZRX-00MMMB0 (3TB, SATA600, 3.5") : 3TB (E:)
Generic- Compact Flash (USB2) : N/A (K:)
Generic- SM/xD-Picture (USB2) : N/A (L:)
Generic- SD/MMC (USB2) : N/A (I:)
Generic- MS/MS-Pro (USB2) : N/A (J:)
PLEXTOR BD-R PX-B920SA (SATA150, BD-RE, HD-DVD-R, DVD+-RW, CD-RW, 4MB Cache) : N/A (D:)
WVO UNWDA7CTEJSL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (G:)
WVO UNWDA7CTEJSL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (H:)
Logical Storage Devices
Sivert (F:) : 932GB (NTFS) @ WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", 32MB Cache)
Reserverad av systemet : 100MB (NTFS)
Data (E:) : 3TB (NTFS) @ WDC WD30EZRX-00MMMB0 (3TB, SATA600, 3.5")
Hard Disk (C:) : 931GB (NTFS) @ SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Removable Drive (K:) : N/A @ Generic- Compact Flash (USB2)
Removable Drive (L:) : N/A @ Generic- SM/xD-Picture (USB2)
Removable Drive (I:) : N/A @ Generic- SD/MMC (USB2)
Removable Drive (J:) : N/A @ Generic- MS/MS-Pro (USB2)
Optical Drive (D:) : N/A @ PLEXTOR BD-R PX-B920SA (SATA150, BD-RE, HD-DVD-R, DVD+-RW, CD-RW, 4MB Cache)
Optical Drive (G:) : N/A @ WVO UNWDA7CTEJSL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Optical Drive (H:) : N/A @ WVO UNWDA7CTEJSL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Peripherals
LPC Hub Controller 1 : ASUS LPC Interface Controller
LPC Legacy Controller 1 : T0 A5-13
Audio Device : ASUS HD Audio Controller
Audio Device : ASUS NI Caicos HDMI Audio [AMD RADEON HD 6450]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : ASUS 4 port SATA IDE Controller
Disk Controller : ASUS 2 port SATA IDE Controller
Disk Controller : ASUS 6121 RAID Controller
Disk Controller : ASUS 64xx/63xx SAS Controller
USB Controller 1 : ASUS USB UHCI Controller #4
USB Controller 2 : ASUS USB UHCI Controller #5
USB Controller 3 : ASUS USB UHCI Controller #6
USB Controller 4 : ASUS USB EHCI Controller #2
USB Controller 5 : ASUS USB UHCI Controller #1
USB Controller 6 : ASUS USB UHCI Controller #2
USB Controller 7 : ASUS USB UHCI Controller #3
USB Controller 8 : ASUS USB EHCI Controller #1
FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : EPSON Stylus Photo R265 Series (360x360, USB, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Scanners and Cameras
Scanner : Canon WIA CanoScan LiDE 200 (Scanner, USB)
Peripherals
Network Services
Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 4.3
Windows 10 (64bit), Core i9 7960X, 128 GB RAM, 6 TB SSD,
Pro Tools 12, Focusrite Scarlett 6i6, Korg Kronos 61, Roland TD30, Godin LGXT, Roland GR55
Old 04-22-2013, 09:29 AM
Default Re: Edit/score window doesn't follow cursor?!?
Sorry for bothering you... Finally figured it out myself...
Old 04-24-2013, 03:29 PM
ondruspat ondruspat is offline
just as a matter of etiquette you should really follow up your post with your solution. Great that you solved your problem but your post doesn't help anyone else.
"Sometimes having limits keeps you sane"- Albee1952
Can mixer be set to follow edit window selections? Protone macOS 2 09-11-2013 05:04 AM
HUI Tascam US-2400 follow edit and mix window Bekkstudio Pro Tools TDM Systems (Win) 1 09-03-2009 04:39 PM
Play Button Flashing Blue, edit cursor doesn't follow plybk Steven Sauve Pro Tools M-Powered (Mac) 1 09-29-2007 10:08 AM
Edit window follow the cursor? D.Orlando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-17-2007 02:55 PM
Edit window doens't follow the cursor... homerg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-30-2005 12:18 PM
