PT 9.0.3 crashes when hiding multiple tracks
When I select multiple tracks and "hide and make inactive", PT crashes.
I found some old threads with the same error for PT 8.something, but I have this behaviour in 9.0.2 and now also 9.0.3. Any news on this issue? |
Re: PT 9.0.3 crashes when hiding multiple tracks
What type of Tracks?
VI's / samplers, can be an issue. eg. Kontakt with MM on purge the cache prior to making in active. VI's without memory management I found purging the DSP cache from the cards to have this happen less. |
Plain audio tracks, no inserts.
I've had this happen but randomly. I don't have an exact sequence of events to repeat.
Hasn't happened here.. fingers crossed.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
I wonder if avid support has anything to say about this?
I've almost learned to avoid crashing, but sometimes it just pisses me off to figure out and redo what I did between the last backup and the crash... |
I was able to reproduce this also, digisupport are you aware of this bug?
Pt 9.0.3 - Digi002R - Imac Dual 3.06 - 8GB RAM - Snow Leopard 10.6.8 - OWC Mercury Elite Pro HD - Akai MPK49 |
Hiding Tracks from a Mix Group in One Command? | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-27-2009 08:32 PM |
8.0cs2 crashes when pasting multiple tracks | zacheus83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-18-2009 08:20 PM |
hiding multiple tracks - shortcut? | jlcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-08-2006 07:21 AM |
Hiding tracks Question | Noiz2 | Tips & Tricks | 1 | 08-31-2005 01:04 PM |
problems when hiding tracks.....A Warning !! | lightning ad | Post - Surround - Video | 4 | 01-09-2005 11:37 AM |
