Digi 002: Errors -6085 and -6088
I just bought this unit a week ago, so if anyone has directions in protools, please help me out with navigating the unfamiliar menues.
My system will record for between 0 and 6 seconds; too short for stuff I hoped to put down. When the h/w buffer and DAE playback buffer are set to higher settings, the recording time will reach a maximum of 6 seconds, but then the error 6085 pops up and stops the recording... (The audio device buffer underflowed. If this occurs frequently, try decreasing the "H/W Buffer Size" in the Playback Engine panel or remove other devices from the audio firewire bus.) Decreasing the H/W Buffer Size and/or DAE playback buffer only also decreases the record time before I either get the 6085 error, or if both or one are set low enough, the 6088 error pops up. (DAE error - 6088 was encountered) I'd say I've spent a good 20 hours reading through posts, going through walk-throughs, messing with hardware settings and so on... I even bought one of the 2 suggested firewire cards hoping that would fix the problem, but it hasn't. The only fishy thing to me is that the IRQ of my Radeon 9550 is set to 16, the same as both the old and new firewire cards I've had in there. Of course, windows won't let me change the address of any card. Is this definitly my problem? Maybe having both on the same IRQ means nothing. If I buy a new video card, can I count on it suddenly being set to a different IRQ? I'm willing to upgrade this new card, but only if I'm sure it'll fix the problem. I'm sure happy to post anything I can about my computer to make this 002 and Protools get working. Please someone, tell me what you need to know, or what I need to do. I think I'm about to cry. Thank you so much, Adam |
Re: Digi 002: Errors -6085 and -6088
I used to have the 6088 problem. Mine was resolved by disabling my soundcard:
http://duc.digidesign.com/showflat.p...ev=#Post747118 |
Thanks alot for the info SumOdRsn. I gave it a shot... I think something must be interfering, but I guess the sound card wasn't it. Maybe I should just keep trying to diable stuff until it fixes it, or until someone can help me out... or until I get frustrated and go for a new video card, fingers-crossed.
Thanks again |
Hey, question: Do you remember if your soundcard was on the same IRQ as your firewire card by chance? Did you check or anything?
Hey Adam, what firewire card are you using?
Also, check through the General troubleshooting thread for a bunch of setup "tweaks" and suggestions, especially the one at the end about posting systems specs. It will help us help you.
Nope, the card was on it's own IRQ. Yeah, check to make sure your firewire card has the TI chip.
This is my firewire card:
ADS PYRO PCI 64 Part Number: API-311 Bus type: 64-bit PCI I went through the entire troubleshooting. I also put in BOTH firewire cards and that prooved me wrong... I eventually got the good firewire card to boost up to IRQ 18, since the other one was in there, so I guess the video card's IRQ doesnt'e make a diff. Same problem still. Here are my system specs: SiSoftware Sandra System Host Name : -- User : -- Domain : -- Processor Model : Intel(R) Pentium(R) 4 CPU 1.80GHz Speed : 1.80GHz Performance Rating : PR1975 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 8kB Synchronous, Write-Thru, 4-way set, 64 byte line size L2 On-board Cache : 256kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector Mainboard Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : No MP APIC : Yes System BIOS : American Megatrends Inc. P1.20 System : P4V88+ Mainboard : P4V88+ Total Memory : 1023MB DDR-SDRAM Chipset 1 Model : ASRock Inc PT880 CPU to PCI Bridge Front Side Bus Speed : 4x 100MHz (400MHz data rate) Total Memory : 2GB DDR-SDRAM Memory Bus Speed : 2x 133MHz (266MHz data rate) Video System Monitor/Panel : Default Monitor Adapter : RADEON 9550 Adapter : RADEON 9550 Secondary Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : WDC WD2500KS-00MJB0 (233GB) CD-ROM/DVD : HP DVD Writer 740b (CD 40X Rd, 40X Wr) (DVD 5X Rd, 5X Wr) Logical Storage Devices 1.44MB 3.5" (A:) : N/A Hard Disk (C:) : 233GB (191GB, 82% Free Space) (NTFS) Pro tools le (D:) : 474MB (CDFS) Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA USB Enhanced Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Infrared Device : Built-in Infrared Device Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Microsoft PS/2 Mouse MultiMedia Device(s) Device : MPU-401 Compatible MIDI Device Device : C-Media AC97 Audio Device Printers and Faxes Model : PDF Writer Model : HP PSC 1500 series Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Adapter : VIA Compatable Fast Ethernet Adapter Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Thanks all -adam |
From the Compatibility page Quote:
I also think I remember someone else on this board having trouble with ASRock motherboards, but I can't be sure. A search for ASRock might turn up more details. As mentioned, try disabling (or removing, if possible) the C-Media AC97 Audio Device Also recommended to disable the VIA Compatable Fast Ethernet Adapter when using Pro Tools. Most of this stuff is covered in the General Troubleshooting thread.
So it looks like I may need to snag another hard drive then.
Hopefully not another mother board also... that'd be a pain. I'll try messin around and reading up some more. If there's anything else anyone can think of, please let me know. Thanks a lot |
6085 and 6088 Errors - Just Started - Sandra Report Included | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-03-2010 02:13 AM |
Trouble in 002 Land: 1394 intermittent, --6088, -6085 errors | dbrunell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 01-04-2010 09:33 AM |
-6088 and -6085 errors, any ideas? | BillDog793 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 11-23-2008 11:41 PM |
6088 and 6085 errors FIXED | Kirby B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-14-2008 11:49 AM |
-6085 / -6088 errors caused by bad video monitor | daeron80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-10-2007 09:02 PM |
