Old 01-28-2023, 08:36 AM
KenSluiter's Avatar
KenSluiter KenSluiter is offline
Default footswitch not working
Hi All,
I'm trying to configure a momentary footswitch for punch in/out control through my artist mix.
I believe I have it configured correctly in Eucon (set to record/record), but Pro Tools (which is in quick punch) doesn't respond at all. I've tried switching polarity and power-cycling the artist unit w/ no luck.
What am I missing?
thanks in advance!!
Old 02-01-2023, 11:58 AM
EddieJones's Avatar
Default Re: footswitch not working
Hi, we have tested this here on a couple of systems. Have you checked that the footswitch is closing/working? You can also check in the Prefs tab Talkback status and see if its being seen.
Old 02-01-2023, 12:44 PM
KenSluiter's Avatar
Hi.
the foot switch does not appear to be "seen" by Eucon. I'm in the prefs tab , and the "status" is empty. I took the foot switch to a friends studio, and connected to his Artist mix and it works perfectly. We're also both on the same version of Eucontrol (2022.9.0.44)
Old 02-01-2023, 01:06 PM
EddieJones's Avatar
Has it ever worked on that unit?
Old 02-01-2023, 01:17 PM
KenSluiter's Avatar
I've had the unit for many years, but this is the first time I've tried to use this feature
Old 02-01-2023, 01:21 PM
EddieJones's Avatar
Can you collect the logs(using the menu item on the icon) and post a link for me? After a full power up and connect so i can see the booting up and whether it even sees it.
Old 02-01-2023, 01:24 PM
KenSluiter's Avatar
thanks for your help w/ this. Not sure what you mean by "using the menu item on the icon"
Old 02-01-2023, 01:40 PM
KenSluiter's Avatar
/Users/kennethsluiter/Desktop/FilesForAvid_2023-02-01_133928.zip
Old 02-01-2023, 01:43 PM
KenSluiter's Avatar
I "collected support files" from Eucontrol menu. How do I get you this zip file?
Old 02-01-2023, 01:46 PM
EddieJones's Avatar
Can you put on dropbox, Onedrive iCloud etc and send me a link?
Footswitch Stopped Working With Mbox Pro Kickdrum60 Pro Tools 11 2 05-02-2017 05:06 AM
Footswitch not working Mbox Pro 2 - Pro Tools 10 gbross Windows 2 03-27-2013 04:11 PM
Footswitch stopped working on 003? DWAGS1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 10-17-2011 04:01 PM
Footswitch has stopped working. MrChrisos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-05-2009 06:23 AM
Footswitch Pe-sound VENUE Live Sound Systems 7 01-12-2009 12:03 PM
