Old 02-13-2018, 11:10 AM
Cheesehead Cheesehead is offline
Default Field Recorder Workflow
Quick question, does it matter how many folders deep wav files are buried for the indexing to drill down into them?
I've just received a new AAF and field recorder workflow is not working correctly on this one.
When I index my Sound Rushes folder the indexing is almost instant.
Can it really be looking at all the files in that time?
This is a feature film, so a lot of files.
Thanks
Ps I'm using 2018.1 (not in my sig yet)
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 02-13-2018, 11:20 AM
melloj melloj is offline
Default Re: Field Recorder Workflow
It tends to be quicker with match criteria than with timecode. Not sure though as far as I know it will search which ever folder you index.
Old 02-13-2018, 11:23 AM
Thanks Melloj,
Hmm, So if you change the match criteria to just timecode, will it re-index based on that?
Old 02-13-2018, 12:32 PM
To be honest I'm not sure, but it seems to do a more thorough search. If you've not seen it I'd suggest Paul Maunders video on youtube he covers the work flow in detail. You might find thd answer your looking for.
Old 02-13-2018, 02:36 PM
DubMonkey DubMonkey is offline
Originally Posted by Cheesehead View Post
Thanks Melloj,
Matching to timecode only will give you a lot of errors, dealing with many shooting days. Select some not so populated track to try different match criteria combination. Another trick is to move all your rushes into your PT session (yeah, I know) and retry the field recorded function thing again...why does it sometimes help? I do not know, but it does (well, sometimes).
Or get yourself EdiLoad, ask the editor for the audio EDL and you`ll be fine
Old 02-14-2018, 02:07 AM
simonchase simonchase is offline
That does sound like something's wrong.
Below is a copy paste of a tried and trusted workflow. The relevant bit is the first bit. It's best to start with a fresh index without any session open. If that doesn't work there may be an issue with your files.
With no session open, delete the index of the soundrolls folder in the workspace. Then index the soundrolls folder in the workspace and wait until it finishes in the task window (This should not be instant) Then open the AAF
Delete all fades (Edit menu)
Make one new blank track and make it a "field recorder guide track". Name the track "1"
Make the "Match criteria" Scene and Take ticked. Other productions may require different settings but this works 99% of the time.
"Select Areas to Search" and add the soundrolls folder then "Save" (Not "Save & Index" as this can cause a crash) Wait whilst it thinks for a while
Move up the contents of track 1 of the AAF to the this new track. Again, Pro Tools may need a while to think about things here.
Expand to new tracks by match criteria
Repeat for the other tracks
Save and close
Temporarily rename the Avid media folder so the session cant find any Avid media
Reopen session. All Avid media will be offline, good, don't relink
"Select offline" in the clip list then "Clear selected"
You're left with just the soundrolls on the timeline
Tidy up a bit (Delete all automation)
Some productions may require a "fix sync" (using Titan if you have it) depending on the recorder used
Cherry on the cake - Use "Defaulter" plug-in
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 02-14-2018, 02:54 PM
Interesting Simon thanks.
There's a couple of steps there that I've not used and I have done this on several films with great success, but not this one for some reason.
Thanks for sending the thorough step by step, I'll give it another go when I get a minute.
Cheers
HTML code is On
Pro Tools 10 Field Recorder Workflow mediaroo Post - Surround - Video 27 02-26-2015 02:31 PM
Field Recorder Workflow pls help! jahtao Post - Surround - Video 4 03-27-2014 05:04 PM
Field Recorder Workflow & PT 9.0.2 Tom Graham Post - Surround - Video 8 03-20-2011 11:39 AM
Field recorder workflow question 2 jahtao Post - Surround - Video 3 12-04-2009 06:11 AM
