Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 11-25-2017, 10:45 PM
WildHoney WildHoney is offline
Default Simple feature suggestion
I find myself using the User1 and User2 buttons to bank quite a bit, but it would be great if I could use OPT-User1 and OPT-User2 (e.g.) to nudge. That way banking and nudging are both at fingertips. If this is already implemented in some other way, and I've missed it, please excuse!
Old 11-27-2017, 07:17 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: Simple feature suggestion
Greetings,
This is not a bad idea. I would only suggest that SHIFT or COMMAND be used - as every other second function invoked from a switch currently on the surface uses SHIFT as the primary, option is the secondary. It's probably also easier for fingers to remember. CMND is closest to the User1 and User2 switches as well.
best,
Jeff
https://www.dropbox.com/s/1ycow9eegk...fiers.png?dl=0
Jeff Komar
Applications Specialist, Pro Audio
Old 11-27-2017, 11:28 PM
Originally Posted by creativecontrol View Post
Greetings,
best,
Jeff
Fair enough!
Old 12-05-2017, 08:08 AM
jmattchan jmattchan is offline
Would love this also.
Old 12-06-2017, 05:18 AM
bucha bucha is offline
Me too !
Bounce feature suggestion spliffonius Pro Tools 9 1 05-12-2011 03:45 PM
Simple Automation Feature Suggestion Nathan W. Pro Tools TDM Systems (Mac) 0 02-15-2010 10:32 AM
feature suggestion poly915 Pro Tools TDM Systems (Mac) 1 06-12-2008 02:44 PM
feature request / suggestion Branko ICON & C|24 2 03-07-2007 08:04 PM
New Feature Suggestion RobMacki Pro Tools TDM Systems (Mac) 0 07-20-2003 01:55 AM
