Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 11-13-2017, 09:16 AM
bucha bucha is offline
Default Recal Faders
Hi Guys,
Does anyone know if there is a "recalibrate" function for the faders, because on my three S6, after building a session with all the faders at 0dB, looking at the faders they look more like a roller coaster.
They're approximately aligned with the 0dB serigraphy and absolutely not aligned between them.
Thanks.
Old 11-14-2017, 07:37 AM
Richard Starkey's Avatar
Richard Starkey Richard Starkey is offline
Default Re: Recal Faders
Hello,
same thing here. Looking for a solution too :)
Old 11-14-2017, 08:20 AM
I tried the local operations in the faders modules (Groups, Steps, etc.) but it doesn't help …
Old 11-14-2017, 11:10 AM
EddieJones's Avatar
There isn't a calibrate. Can you post a picture of how bad this is ?
Old 11-15-2017, 06:26 AM
clipgod clipgod is offline
same on my recently purchased S6. It is pretty bad, please have a look at a picture I took with all faders at zero in Pro Tools.
Old 11-15-2017, 09:20 AM
EddieJones's Avatar
That's strange, not seeing this here. Can you go into test mode on a Fader Module (hold Select and Swap on the first strip) then select Fader and then Group. Moving one fader they should all move together. The numbers should be within about +-30
The Menu keys are the selection. The far right one is Exit
Also without tracks on the faders (or the system turned off) when the faders are down at the bottom are they inline ?
Old 11-16-2017, 03:52 AM
Hi Eddie,
please have a look at the attached pictures, showing the faders at zero, somewhere in between and fullscale. I also included a picture with all faders at zero, no session loaded. They more or less line up, but when I have a session with all faders at zero db, they don`t line up at all
Old 11-16-2017, 09:50 AM
EddieJones's Avatar
The somewhere in between is the interesting one. they should be roughly level. So this proves its not The S6 or PT software. We have a module coming back to the factory for investigation.....I'll report back as soon as we get it.
Old 11-28-2017, 12:13 PM
EddieJones's Avatar
Its looking like a batch of faders from TKD (the manufacturer) have a wider tolerance than before. We are in communication with them about this whilst they investigate. These faders have been used for 15 years (from back with Euphonix) and have always been within +-1mm so something must have happened in their process to align them.
As well as working with them we are looking at other solutions. For now I would suggest not returning the modules as other than the cap being out of alignment with the lexan they will work as normal (its not an electrical issue). Thank you for your patience and I will keep you updated.
Old 12-01-2017, 02:33 PM
laki laki is offline
Hi All, I’ve got a bunch of these as well. At least 4 buckets are doing this across different desks. All faders report 0db when you touch but they are out of alignment. A real mind game when you’re actively mixing two mics against each other.
Sticky Faders, GUI Lag when moving faders Intransit Pro Tools 12 10 02-04-2016 09:31 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 10:56 PM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 07:44 PM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 08:06 PM
recal old version of virus rather than indigo monkey Pro Tools TDM Systems (Mac) 1 01-09-2003 08:58 PM
