Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 09-19-2017, 02:55 AM
bucha bucha is offline
Default Pick up Mode on Joystick Module
Hello guys,
I have the following issue with the Joystick Module in Pick Up Mode :
When the white dot approaches the red dot, the red dot jumps into the white dot (magnetic way).
I firstly thought that it was only a little bug of the display on the module, but the pan acts exactly the same way in protools.
As a result, you have a jump in the pan automation your writing.
Old 09-19-2017, 05:07 PM
EddieJones's Avatar
Default Re: Pick up Mode on Joystick Module
Yes, there is a little space around the dot where the pickup works, this was to enable you to better grab a moving dot. We will look at tightening this up though.
Old 09-20-2017, 10:23 AM
Hi Eddy,
May be another Pref where you can setup this parameter ?
Old 09-20-2017, 10:42 AM
EddieJones's Avatar
Not another pref ;-) I think we should just get it right.
Old 09-22-2017, 12:47 PM
EddieJones's Avatar
We made this much better and will be in v3.7
S5 Joystick module calibration Steven1145 System 5 4 09-18-2017 11:11 PM
Knob Module Parameter in Layout Mode Bill_Meadows Avid S6 12 08-30-2017 08:58 PM
Joystick S5-MC Gregor B. System 5 7 03-23-2017 10:39 AM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 11:30 AM
PT doesnt pick up audio outputs from a Proteus sound module Amnesiac MIDI 2 04-17-2008 03:21 AM
