Old 10-28-2011, 07:51 AM
DarkDayz DarkDayz is offline
Default sample rounding error in pro tools 10???
I was just wondering if sample rounding errors still occur in Pro Tools 10. I am not talking about the amplitude. In all previous versions of pro tools le and 9 the grid was off a couple of samples. So if you dublicate regions it would just cut off the beginning which is a nightmare. This does not occour with 90, 60 or 120 bpm because no rounding is needed. Could someone please try to repeat a region (20x) with any other bpm (not 90, 60, 120) an have a look if the regions line up with the grid!?
Thanks...
Old 10-28-2011, 09:05 PM
Default Re: sample rounding error in pro tools 10???
anyone in to check if pro tools 10 is acurate?!
Old 10-28-2011, 09:45 PM
RTFM RTFM is offline
Yes, this is still the case. The solution is to put the track into Ticks mode before doing the region duplication.
Old 10-29-2011, 05:02 AM
I tried in tick mode but it´s still the same problem. You can also display the amount of samples in the main counter window. You will see that the amount of samples are not the same for one bar.
for example 87 Bpm
1st Bar 121655
3rd Bar 121656
Here is a screenshot after 20 dublicates
http://darkdayz.de/sampleRounding_1.tiff
Like I said it does not occour with 120, 60 or 90 buth with any Bpm in between. When I try the same with live, logic or cubase the regions line up. I was always asking myself why I get phasing issues when I place a snare underneath a drumloop. After a few regions it just starts to phase because the grid is off.
I would buy the upgrade to 10 but I need to be sure that sample rounding does not occur anymore. So it would be nice if someone could just check that.
Greets Kai...
Old 10-30-2011, 06:17 AM
RussUK RussUK is offline
It's fixed.
As asked 87bpm, recorded a drum loop for a bar.
Every single bar after being copied is 132414 samples
I work with amazing people who do amazing things.
Founder of the Expert Sites.
Old 10-30-2011, 06:28 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by RussUK View Post
It's fixed.
Are you using copy or duplicate Russ?
would be fantastic if this IS fixed
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 11-02-2011, 04:22 AM
Aquarius Aquarius is offline
Bump !
Sample Rounding budda963 Pro Tools 11 1 07-08-2013 07:07 AM
PT and Sample Rounding WILL cause Issues when Copying 25ghosts Pro Tools TDM Systems (Mac) 7 07-01-2011 03:25 AM
Sample rounding issues bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2007 09:20 AM
Sample rounding, ticks, etc voce Pro Tools TDM Systems (Mac) 1 08-03-2005 06:26 AM
ENUFF GRABASS!!! Sample-rounding BUG!! s2n Pro Tools TDM Systems (Mac) 9 02-15-2004 02:51 PM
