Old 09-13-2011, 05:32 PM
magicaldog magicaldog is offline
Default Eleven Rack and a BOSS FV-500-L expression Pedal ? ? ?
I can get one of this ( http://www.thomann.de/se/boss_fv500l.htm ) at a good price but how do I find out if the expression function work with my Eleven Rack ?
Any help is greatly appreciated !
Thanks !
Old 09-13-2011, 06:14 PM
Default
Thanks !
It will work fine. When used as an expression pedal these looks like an EV-5 so set the Eleven Rack to expect an EV pedal.
The expression pedal behavior of the 500L and 500H should be the same so just choose which model you want for use as a volume pedal (if you care at all about that).
Darryl
Old 09-13-2011, 06:46 PM
Thumbs up Re: Eleven Rack and a BOSS FV-500-L expression Pedal ? ? ?
Darryl
Thanks Darryl
Old 09-14-2011, 02:04 AM
Mister_Riff Mister_Riff is offline
Default Re: Eleven Rack and a BOSS FV-500-L expression Pedal ? ? ?
I use the FV 500 H and it works great!
Guitars: Schecter C-1 Blackjack ABSN, Ibanez RGA 121
Amp: ENGL Ritchie Blackmore
Effects: TC G Major 2
Awesome: Eleven Rack (with EXRP)+ M-Audio Bx8a's
Old 09-20-2011, 11:13 AM
julyen julyen is offline
Just to let you know, I have the FV-500-L and it works well with the Eleven Rack.
Old 09-23-2011, 06:13 AM
Thanks everybody for your input !
Old 06-18-2012, 07:23 PM
I bought the BOSS FV-500-L and has already replaced it for a new unit once !
I only use the expression jack and after using it for a couple of days I noticed it became very glitchy and did not have a smooth travel especially on wah pedal.
I replaced it with a new pedal and now that has the same issue
Choose AVID if you really want to be sincerely Screwed !
Old 01-15-2014, 06:12 AM
Tony-N Tony-N is offline
So how did this turn out for you?
Have you abandoned the Boss pedals for expression with the 11R?
I sold my EV-5 a few years ago but am thinking about getting e new one, but now I'm starting to get a little worried about the quality even though the one I hade felt good even though it was plastic.
I didn't use it very much so I don't really know how the pedal will stand the test of time but would like to have something small like that to use with the wah-wah on the 11R.
Old 01-15-2014, 07:48 AM
I have replaced it 4 times now and it's been several months now since the last time but this one is still glitch free ''
I don't use mine on a daily basis but whenever I do have to work it a bit to have a smooth transition between heel and toe. The pots clearly aren't top quality !
They must have had a really bad batch but it's now about 18 months since I first bought the first one.
However - Next time I am going to think one extra time before I put my money on a BOSS pedal !
Old 01-15-2014, 08:36 AM
Thanks for the reply.
Wow, 4 times!
Guess those plastic Boss pedals are out of the question then...metal it is.
Roland expression pedal not functioning properly with eleven rack lbar11 Eleven Rack 9 03-16-2017 11:35 AM
Using Ernie Ball Volume Pedal as WAH Expression on Eleven. ? Need your help fast! awritersparadise Eleven Rack 18 11-15-2012 07:48 PM
Eleven Rack Expression Pedal brianiac5150 Eleven Rack 13 12-10-2011 06:33 AM
11 Rack & Expression Pedal as Wah and Multiple EFX VOX59 Eleven Rack 10 11-20-2011 01:43 PM
Exp pedal w/ Eleven Rack and 003 rack weirdness. decayd Eleven Rack 1 08-07-2011 04:56 PM
