Old 02-19-2005, 10:25 AM
Fabien Fabien is offline
Default Midi won\'t work with my Digi002 Rack
I recently bough a Digi 002 Rack, took it back home and connected/installed it to my computer. Audio works perfectly, but it seems that the midi ports aren't really recognized. When I'm in ProTools, even if everything seems to be alright (when I play on my keyboard on a record-enabled track - with Midi Thru activated - the track do receive and record signals) but NO SOUND comes out... When I look in Setup > Periphericals then Synchronization, right to "Generic MTC Reader", there's only the keyboard I installed in the Midi Studio Setup instead of the Digi002r.
I tried other midi software (drumbox, cubase), they all recognized the Asio Driver of digidesign but the pb is the same.
Could someone help me ?
for info, I work with :
P IV 3,6gh
1024mo RAM
WinXP SP 1
ProTools 6.7 CS8
digidesign Wave and Asio drivers up to date
Digi002Rack
MicroKorg
Old 02-20-2005, 02:52 AM
Default Re: Midi won\'t work with my Digi002 Rack
Please, anyone ?
Old 02-20-2005, 03:13 AM
dramsenik dramsenik is offline
without further info it seems you have an external sound module/synth?
if you're using softsynth please check that you do exactly the same as here replace ST with your softsynth and there you go
IF you are using hardware (then midi out) then be aware of this:
which language version of Windows XP are you using?
There's still some issue reported with some european language and 6.7cs8:
french,spanish seems to be OK
german and italian don't work
read the thread here
Old 02-20-2005, 03:27 AM
I use a hardware synth. A few days ago, I installed CS8 because I though it would help me (I had saw the topic about CS8) as I live in France. But the problem still remain...
But if it was the problem, don't you think that the midi port out would work with another soft ? because I tried with another software (cubase sx2), and the problem is the same...
Any help ?
Old 02-20-2005, 03:47 AM
The Patch Editor of my keyboard works well, communicate with the hardware. So it's not a technical problem. But I still don't hear a sound...
Old 02-20-2005, 05:10 AM
Aussie Scott Aussie Scott is offline
This might seem out of order, but when you say you don't hear a sound - have you got the audio outs of the sound module connected to a mixer/amp or something? Don't mean to be rude dude
"...I asked you not to tell me that!"
Old 02-20-2005, 05:38 AM
Yes that's rude...(Just to comfort you Aussie )
You could say also have you powered it on?
Old 02-20-2005, 07:37 AM
The Audio Output of my synth is connected to the audio input of my Digi002R, and when I use my keyboard in audio it works. But when I only create a midi track, select Channel 1 in input, Channel 2 in ouput (of my keyboard), select a bank, a patch, enable Midi Thru and Recording, I can't hear a sound. I haven't created any audio or aux track because I only want to work in midi with this project...
Old 02-20-2005, 05:25 PM
So what's the point?
it's normal that you hear nothing if you don't create an auxiliary track.
you can always delete it after use...
or use a headphone directly connected to your synth to work.
Old 02-20-2005, 05:30 PM
I read once again your post ...it's not so clear what you are trying:
please write a step by step of what you do.
Does digi002 rack work with pt 10 pken.santschi@bluewin.ch macOS 8 03-17-2012 02:02 AM
Will my system work with a Digi002 Rack clarkepr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-19-2004 09:15 PM
Will digi002 rack also work with qbase? tylerhbrown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-27-2004 12:19 PM
USB MIDI and Digi002 Rack oreo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2004 10:45 PM
Will the Digi002 rack and 0s9(5.2) work? Dan M. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-21-2003 03:55 PM
