Old 12-29-2015, 03:07 PM
yorgo yorgo is offline
Default Audio files, where are they?
So I've noticed that not all my audio files are NOT in the project audio files folder. Is there something I can check off to make this happen....btw where do they go?
Thanks
Pro tools 11.3, Windows 7 Premium,
Desktop i5 4670 3.4ghz 16G ram quad core
Old 12-29-2015, 03:20 PM
Drew Mazurek's Avatar
Default Re: Audio files????Where are they
You haven't moved the session around from drive to drive via drag and drop have you?
If the session opens ok, then simply chose: file menu, save session copy, and click all audio files and PT will gather them all up into a new session for you.
www.drewmazurek.com
Old 12-29-2015, 04:00 PM
sw rec sw rec is offline
Also, go into preferences and check "copy files on import."
Old 12-29-2015, 06:18 PM
Indeed, there are several ways for a user to mess this up(trust me, I learned the hard way). 2 things I will toss out for you:
#1-whenever I import audio, no matter where it comes from, I ALWAYS move/copy it into the session folder, BEFORE I use the Import audio command.(I have had "copy files on import" checked in preferences, but still had imported audio still come up as off-line)
#2-if you open a "template" session and then(once it has opened) you save it to your recording drive, this is not the way to do it. either CREATE a new session from a template(not sure what version of PT you have, so there may be stuff you are not aware of). Or, create a blank session on your recording drive, then go to File>Import session Data>point to your template session and import all the tracks(this was/is the work-around in older versions of PT that did not offer the ability to "Save as Template"(from the FILE menu)
Old 12-30-2015, 09:54 AM
A good habit that I need to do every time!
Old 12-30-2015, 10:30 AM
Craig F Craig F is offline
In the Clip Bin: Show Full Path
That will tell you were Pro Tools thinks the Files are
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
usaved PT session saving unsaved audio files to audio files folder mermermer Pro Tools HDX & HD Native Systems (Mac) 1 07-18-2012 12:50 PM
Audio files on one FW Drive render blank audio files when copied ridmik Digidesign Hardware & Software 4 03-30-2012 01:55 PM
All Sessions using SDII files are missing all audio files and won't relink bigmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-18-2009 01:54 PM
fade files and elastic audio files in wrong place studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-14-2008 03:56 PM
Fade Files as Audio Files in "Missing Audio" ?? CCash Pro Tools TDM Systems (Mac) 6 05-18-2005 10:00 AM
