time compression sw, or, how to do drums?
Here's my dilemna.
I am not a really good drummer, I can get the job done, especially if the tempo is not up there. Problem is, I want to record stuff where the tempo is 'up there'. I have set of electronic pads feeding a DM Pro and was wondering...can I play the stuff in half time, and with some help from some software or advanced PT technique, effectively double the tempo? Another solution I guess is to use loop libraries for the drums...I dont like that idea because you have no control over the drums individually...it is just a stereo track. Unless there is something I'm missing. I dont want to spend my life 'stepping' drum parts into PT either. I have better things to do with my time. |
Re: time compression sw, or, how to do drums?
Sonoma,
Check out a product called "Drums on Demand." They are great drum loops organized into song forms. Also, what kind of music do you do? I am a drummer and am currently set up to record my kit. I can play all styles. Maybe we can work together on each others projects. My best styles are jazz, pop, rock, country (If needed), world (reggae, latin, etc) The only style I would have to "fake" it a bit is in VERY heavy metal requiring lots of double bass stuff. Good luck man! |
I think there is a way of recording in half time.
To play in half time you press shift + spacebar, so I suppose to record in half time to pro tools you press control + shift + spacebar. Not at my PT machine so cant check it out...give it a crack though neeel.
MBOX MINI PTLE 8.0.3 MAC OSX Snow Leopard Mac Mini 1.5Ghz Intel 2 Gig RAM ******************* |
Use redrum and write your drum parts with midi when your done just raise the tempo.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
Hey Neeel, I tried this and it worked...is there any way to do it w/o affecting the pitch? I guess I could go step it down an octave after it's been recorded...but is there a way to bypass that step and get it in true pitch at half tempo?
Thanks! |
Best Hardware Stereo Compression for Drums, Under $2000? | tj7 | The Drum Room | 2 | 05-18-2011 01:58 AM |
Reverb and Compression on Drums | drumkid | Tips & Tricks | 5 | 06-13-2005 01:34 AM |
does anybody record drums with no compression in? | keithl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 12-09-2004 10:58 PM |
time compression | funkdoctor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-03-2002 02:10 PM |
Time compression | coaster | Pro Tools TDM Systems (Mac) | 4 | 10-22-1999 06:45 PM |
