Old 02-10-2017, 11:04 AM
jgiannis jgiannis is offline
Default ProTools - Apply AudioSuite FX to Clip Handles
Hi.
Is there a way to render an AudioSuite effect on a clip, such that the affected clip will have handles?
Currently, I'm cutting a ton of clips and assembling them across my track. I then go back and render some clips with FX. But I want the affected clips to have handles.
Is there a way to achieve this?
I'm currently using PT 10, but let me know if 11 or 12 has it too.
Thanks!
PS,
I initially thought that I could achieve this when I saw a setting for it.
In PREFERENCES > PROCESSING TAB > AUDIOSUITE > DEFAULT HANDLE LENGTH "WHOLE FILE" OR "CHOOSE LENGTH"
This sounds like exactly what I'm looking for, but it does not operate the way I wanted. Currently, my affected clips do have handles, but the handles are silence for some reason. Also, when I select the "WHOLE FILE" setting, the "silent" handles do not extend to the original file length. Hopefully my system is just acting buggy, because I was almost certain that this preference would solve my issue.
Old 02-11-2017, 11:10 PM
Fionn Lucas's Avatar
Fionn Lucas Fionn Lucas is offline
Look down on the bottom right of your audiosuite plug and see a box with 0.00. Type in the length you want your handles to be.
A Couple of Protools 11 "bugs" handles processed with clip gain electroteque Pro Tools 11 0 07-25-2014 10:45 PM
Blank Handles with Audiosuite in Protools 10 electroteque macOS 7 12-05-2012 10:08 AM
Audiosuite w/ handles mentalsanityoff Pro Tools 9 1 04-16-2012 03:35 PM
Next PT comes with AudioSuite handles!!! nedd Post - Surround - Video 34 03-05-2012 06:21 PM
Apply edit feature (WAS: need Audiosuite handles) reichman Pro Tools TDM Systems (Mac) 0 12-04-2006 10:43 AM
