Cloud Collab bug with plugin automation
This can´t be normal! when PT reads plugin automation during playback it changes the "upload changes" arrow into green (e.g. something has changed). But it was only an automation read, not an auto-write.
It does not happen with track automation (vol, pan etc) only if you auto-enable a parameter of a plugin. Tried it with Air VIs Air plugins and Avid EQ7. This is not the correct behaviour isn´t is? Makes no sense!
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: Cloud Collab bug with plugin automation
I don't have an answer, but freezing the track with the automation could be a solution(or use Commit)
yes, Track Freeze could be a solution, the best one would be that plugin parameters with active automations must be ignored for collaboration updates when only playback occurs!
Cloud collab EULA question | bcwiz | Pro Tools 2018 | 9 | 05-23-2016 08:26 PM |
Pt 12.5 cloud collab says my projects are used up but i havent used any yet | HALO1THEGREAT | Pro Tools 12 | 2 | 05-09-2016 03:51 AM |
Cloud Collab video from Sweetwater | JoelG | Avid Cloud Collaboration | 14 | 03-04-2016 01:40 PM |
PT Cloud Collab Webinar 3/15 | Tom Graham | General | 0 | 03-04-2016 09:46 AM |
