Clip Effects Consolidating with fades and handles in tact
I work in post-production as a sound editor and mostly collaborate with other folks who are pro tools users. However, once in a while I have to deliver a project for re-recording mixers who are using Nuendo and other DAWs, in which case I'd like to prep an AAF for them.
I tend to use a good amount of clip-based EQ for dialogue editing and sound effects editing/sound design, but wanted to know if there was a way to "render" the clip-based effects within each clip while leaving the handles and fades in tact. This would be a similar manner of how you can "render" audiosuite plugins and choosing "create individual files" and "clip by clip" from the audiosuite plugin's menu. Thanks so much! Jon |
Re: Clip Effects Consolidating with fades and handles in tact
Wel...I figured out how to "render" clip based effects for the whole sequence by right clicking on the clips and choosing "clip effects > render." However, when exporting an AAF from pro tools, it doesn't keep the fades in-tact for any clips regardless of whether or not they've had clip eq processed. So this completely makes AAF exports from Pro Tools useless which sucks. And if I wanted to simply render all of my clip fades I'd either have to do that as a batch which creates audio files for the whole sequence, or do them individually using option + shift + 3.
Hey jondom22,
Could you not 'consolidate' all of your individual clips and render your fades by using an Audio Suite effect (such as the gain plugin - with no setting changes, just nominal 0 gain increase/decrease) and use that set to individual clips with the handle length you are looking for? Couple that with a batch clip rename command of taking off the AS append... Is that close to the result you are looking for? |
ProTools - Apply AudioSuite FX to Clip Handles | jgiannis | Pro Tools 10 | 1 | 02-11-2017 11:10 PM |
PT 11.3.1 Freezes when Consolidating clip | gillbert1027 | Pro Tools 11 | 3 | 04-11-2016 02:42 PM |
Consolidating regions and fades | tritonkorg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-21-2015 06:53 PM |
Trim selection of faded tracks, keeping fades in tact | phillyt2k | Pro Tools 10 | 0 | 03-04-2014 10:34 AM |
Consolidating Fades | mentalsanityoff | macOS | 5 | 06-10-2013 03:58 PM |
