Old 04-21-2013, 07:58 AM
Rumandolin Rumandolin is offline
Default MBox 2 Pro Monitor knob has stopped changing monitor levels
Hi - I've developed a weird problem with my MBox 2 Pro: the monitor level knob no longer changes monitor levels, which are now fixed at the same level regardless of knob position.
I've so far tried reinstalling the driver, which hasn't changed anything. Also, the headphone level controls are both working as they should.
Could there be some setup option in PT I've missed, or some software setting I'm not aware of that I need to change? If not, does anyone have idea what could be causing this?
Thanks a lot for reading - any help much appreciated.
Old 04-21-2013, 09:13 AM
Default Re: MBox 2 Pro Monitor knob has stopped changing monitor levels
Problem solved! Which is good, but embarassing: MBox had been borrowed and put back with the monitor cables in the line out sockets (that'll teach me not to double-check!).
Sorry for anyone's wasted time.
Monitor out togheter with monitor volume knob kennylovrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-22-2006 08:19 AM
No monitor levels from mbox 2 Dm55 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-25-2005 11:36 AM
MBox Monitor levels and white noise on playback Zaxxon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-03-2004 10:41 AM
MBox Monitor levels and white noise on playback Zaxxon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-01-2004 01:35 PM
Non-linear Output From Monitor Knob AIllusion ICON & C|24 5 12-21-2001 12:18 AM
