Old 11-07-2013, 09:02 AM
ahmedasbac ahmedasbac is offline
Default digidesign 002r not working in windows 7 32 bit-Nuendo 4/cubais5
hai..
I am new to this community. recently i purchased a used digidesign 002 Rack. I am using nuendo4/cubaise5. but i cannot use these in windows 7 32 bit system, with the latest standalone digidesign driver for windows 7 installed, smoothly. every thing is OK but the playback is noisy. I tried different versions of drivers, but in vain. then i installed windows xp and found the things work smoothly with digidesign driver version 7 installed.
Is there any way to use digi 002 r in windows 7 32 bit with nuendo4/cubaise5?
pls help...
Old 11-07-2013, 05:41 PM
Default Re: digidesign 002r not working in windows 7 32 bit-Nuendo 4/cubais5
The biggest question is whether the 002r actually works. Are you aware of the "power harness" issue? Step #1 for me, would be to find someone using either 002r or 003r and trying your 002r on their system. 1 important warning here...never(and I mean NEVER) hot-patch 002 or 003 boxes as this can fry the FW circuit in the interface, the computer, or both. Since you have the rack unit, there may be a simple fix. Pop the lid and face the unit towards you. The PSU will be on the right side and has 2 plastic Molex connections, 2 wire coming in, and maybe a dozen colored wires going out(this is the power harness). I would unplug/re-plug both of those connections 5-6 times each. Then follow the harness out to 2 more connections and repeat for each. This action MIGHT scrape thru the oxidation and make the unit work again(its a free trick that just might reveal if the harness is the problem).
Old 11-08-2013, 10:41 AM
SKI's Avatar
SKI SKI is offline
That makes it appear that the unit is functional
URBAN MUSIC-
(Hip Hop and R&B)
Old 11-08-2013, 12:37 PM
DOH
digi 002r intermittent in windows 7 yet working perfectly on XP christopher.tempest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 01-01-2010 01:12 PM
digidesign interface with nuendo? krevet Tips & Tricks 4 08-11-2009 06:23 PM
digidesign interface with nuendo krevet Digidesign Hardware & Software 1 08-11-2009 04:22 PM
ASIO 2.0 + Digidesign TDM Mix plus + Nuendo = ???? Black-Rose Pro Tools TDM Systems (Win) 2 11-09-2004 03:49 PM
Digidesign USD with Nuendo Allx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-25-2001 04:27 AM
