8.0.4 latency adjusting issue?
been using the le 8.0.4 on win 7 prof 64bit.
2 things happened recently. never had these problems before all ran smooth. 1. while recording a session randomly got blue screen. not sure about that one. 2. while recording at any buffer ( I use 64 or 128 mostly ) I am able to record to the click and drums no problem and its on time. however when I play back the recorded track it sounds early to everything else. I have to move the track milliseconds to the right to line it up in time. its weird. like pt is adjusting the track and making it off time on the grid by putting it a bit earlier. anyone else experiencing this? is there a setting that I might have on that I didn't know does this or is it a glitch? I was recording a band yesterday were having problems with the guitars. client thought they were sucking when it was the program. thanks also it seems to be happening randomly. can it be plugins? this is a weird one.
AMD Phenom(tm) II X4 955 Processor 3.21GHz Gigabyte GA-790XTA-UD4 Total Memory : 4GB DIMM DDR3 Memory Bus Speed : 2x 670MHz (1.34GHz) western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:) western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (D:) Memorex DVD+-RAM 550L v1 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Windows 7 Ultimate 6.01.7600 x64 gateway 24inch hdmi dvi HD monitor pro tools LE 8.0.4 |
Re: 8.0.4 latency adjusting issue?
if SANSAMP is one of the plugs then its' latency isn't bein' reported correctly. do a search on it...it's a recent thread.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
I was not using sansamp. did a search nothing came with any of my problems
heeeeeey i'm having this issue too. have someone figured it out some workaround?
Mee tooo!!! Help
Guys... as pj pointed out, this is a big issue with a 10 page thread...
Pro Tools placing sound EARLY?? |
Adjusting the midi for latency? | Intuition | Windows | 4 | 12-09-2013 06:59 AM |
Buffer Latency - Adjusting tracks recorded at various buffers | pauledwards | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-14-2012 10:19 AM |
Adjusting for latency drag in L6's Podfarm | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-08-2009 07:35 AM |
adjusting recorded audio by system latency? | Tweakster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-05-2009 10:41 AM |
Adjusting for Latency with the RTAS 2 VST Adaptor? | _Dova_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-30-2004 10:49 AM |
