7.1cs closes after ten minutes
K this is a new one. All of a sudden my session's just close and Pro Tools quits with no message. Got an assertion error this morning saying that I couldn't save my session, restarted and that went away, now I have this problem. Anybody seen this?
Re: 7.1cs closes after ten minutes
You need to give a lot more information about your PT system and mac version and OS etc! plus all your settings in PT! then someone could advise and help. come back soon Chris
I'm assuming it's 7.1cs9 since you had the assertion problem. If you haven't already, you should repair disk permissions and go through all the usual troubleshooting steps. I never saw that behavior when I was (briefly) on 7.1cs9, but it sounds like an unhappy system that needs some attention. You might consider either upgrading to 7.2cs1 or downgrading to 7.1cs8. Either wa, it's probably a good idea to reformat your system drive and install everything from scratch.
that did it...many thanks...
Scorch 1.2 closes | Fraser.Sims | Avid Scorch (iOS) Forum | 6 | 09-26-2013 01:00 AM |
Cant save or closes | noelooo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-06-2009 01:34 PM |
PT 7.4 closes | jrosado458 | Pro Tools TDM Systems (Mac) | 3 | 12-20-2007 05:39 AM |
PT LE 7.1 closes on digirewire.dpm | tone matrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-21-2006 07:48 AM |
And Pro Tools Just CLOSES??? | MUSIKxDRUMR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-21-2005 04:55 PM |
