Old 06-13-2005, 10:33 AM
jrlmusic jrlmusic is offline
Default Error Bouncing to disk in .wav format
I am unable to bounce projects to a .wav file.
When I try to do so, it goes through the process of playing the song through the MBox, counting down the time, and even creates a file. When I attempt to play the file with Windows Media Player, the media player attempts to connect to the internet to search for a codec. It then reports that it could not find the necessary codec, and the file will not play. I've tried installing the codec update for WMP but still have the same problem.
I have no problem bouncing to .mp3 (except that they sound like crap...).
I appreciate any suggestions.
-Jeff
Old 06-13-2005, 10:39 AM
spkguitar's Avatar
Default Re: Error Bouncing to disk in .wav format
Jeff, welcome to the DUC.
With what samplerate/bitrate are you bouncing the files? Are you bouncing them as stereo interleaved? It sounds like you are bouncing files at a higher samplerate/bitrate than WMP can read.
A better question might be, what is your intention with the bounced wav files? Ar you going to burn them to CD? Send them to a mastering engineer? Send them over the internet?
Old 06-13-2005, 10:48 AM
Bastiaan Bastiaan is offline
for a normal audiofile bounce to stereo-interleaved/16 bit/44.1 or 48 hz.
If you want to burn to CD bounce to setreo-interleaved/16 bit 44.1 Khz.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 06-19-2005, 03:20 PM
Thanks for your help, guys. I was bouncing in stereo interleaved / 24 / 44.1.
My goal is to master the songs with SoundForge, burn to CD, and send it off for pressing. Once I changed it to 16, it worked fine.
-Jeff
Error when bouncing to disk Helge Krabye Pro Tools 10 5 09-17-2013 01:29 AM
Error when Bouncing to Disk MissingCat Pro Tools M-Powered (Win) 2 05-13-2007 07:19 PM
when bouncing to disk this error comes up? jackp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-26-2007 05:31 AM
Trouble Bouncing to Disk with Mp3 file format kurkomat Pro Tools M-Powered (Win) 2 01-09-2007 11:08 AM
problem bouncing to disk in AIFF format moon1pulse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2006 04:04 PM
