Old 03-05-2021, 06:56 PM
RoskoVair RoskoVair is offline
Default Automation is grayed out, won't un-gray
Hello,
I'm new to the community, so I'm sorry if I'm not putting this in the right location... There are a lot of places to post here!
I learned from this video that you can automate your plug-in, specifically the bypass. I followed the instructions in the video, but the automation is not being read, despite being there. I noticed that the selection bar grays out (see screenshot) when I have "(fx a)" selected, whereas it appears normal when any other thing is selected (volume, waveform, etc.).
So I looked in the forum here and it looks like this happens when automation is suspended. So, I went to window, automation, and looked at it, but it doesn't appear to be suspended (see screenshot). In fact, it didn't matter what I clicked on, but none of those buttons did anything.
Is there something big and obvious I am missing here, or should I maybe start over...? Thanks for reading.
Old 03-05-2021, 10:56 PM
falcowe's Avatar
falcowe falcowe is online now
Default Re: Automation is grayed out, won't un-gray
The only other things I can think of that would display like this is,
1. Fx(A) is inactive and you need to activate the plugin.
2. Fx(A) has no plugin instantiated so there is nothing to automate.
Also.. I’m sure you were, but double checking. When putting in the automation are you writing it in by and hand (i.e. drawing new points of data) or trying to click and drag elements or automate with a control surface? If the latter then make sure you are in the write automation mode for the track in question and that the parameter (esp for plugins) is automation enabled (but I think the video you referenced had that in it).
MacPro 7,1 (sigh) 16-core, 128GB ram, W5700X GPU, RME UFX+, PT 2020.11U.
Artist Mix, S1, and PT|Dock.
And too many VIs and VEPro machines.
Old 03-05-2021, 11:05 PM
Top Jimmy's Avatar
You managed to bypass the bypass automation . Command-click it and it will re-enable it.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Gray Compressor Roulette Records Pro Tools 2020 15 02-11-2021 11:10 AM
Automation Read Is Grayed Out philip888 General Discussion 3 04-13-2010 01:27 PM
in the gray groovilator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-18-2006 11:23 PM
WHY WOULD AUTOMATION READ/WRITE BE GRAYED OUT? Pete Weaver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-08-2005 09:15 AM
Why is the DSP usage is gray out ??? vudoo Pro Tools TDM Systems (Mac) 1 10-25-2001 01:49 PM
