Distance from the mic
I was wondering what is the ideal distance from the mic to record vocals. Sometimes my vocals have an very aggressive low end, and kind of windy, as if the singer was bloqing into the mic. It does not sound professional at all. Is this an issue of how far away the singer is from the mic? also, is there an ideal level/volume to record vocals?
thanks! Enviado desde mi iPhone utilizando Tapatalk |
Re: Distance from the mic
'Sounding professional' doesn't really mean much. Sounding good to the ear is a better term. Also take into account the type of music being recorded. Paraphrasing a term drummers use: sing to serve the music. Don't do screamo style if you're going for a James Taylor sound. As to level - record at such a level you don't overload the front end (preamp and converters). Adjust levels after recording to get the vocals to fit the mix. By adjusting vocal levels you can have them more upfront (louder) or further back (softer). And don't forget the pop filter in front of the mic. |
Steve Shepherd Extreme Mixing |
There are no rules punchline fits this question very well.
Distance to mic is simple: the closer you are, the less your room affects the sound, the farther you are, the room affects more. Another thing is levels. There's absolutely no reason to "hit red" with an AD converter that has 124dB dynamics at best -- you will always have at least 20dB headroom below full scale. Any time you hit over -20dBFS you're only amplifying noise. Period. :)
Steve
Random thoughts(great info already given):
1-plosives will be lessened by distance(8-10" or even more) a pop filter(highly recommended unless you are going to be 12" or more away from the mic, or place a pencil against the grill(dead center) and attach with rubber bands 2-backing away will lessen proximity, but that will increase the amount of room sound, making acoustic treatment more important. Acoustic foam is mostly too thin to be effective so I would buy rigid roxul or fiberglass panels(eBay is actually a decent source) and frame up some panels 2-3" thick and treat nearby walls and ceiling. 3-if your mic has multiple patters(like Cardioid, Omni, figure 8), try each to see if any improve your result(Omni usually has no proximity effect and figure 8 usually has the most)
Double pop filter the mic. For pop/rap/metal/rock et al. Mesh and foam baby. Then they can get in on the mic. You can try the old pencil trick (pencil in front to divert the blasts).
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. |
Answers are easy to find when there are microphones involved, try different positions, distances, angles, filters until you get the best combination, nobody will be more helpful than your own patience to test all options available and find one that delivers what you need. Good luck
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Pencil trick I must try this, never heard of it before....... Everyday is a school day :)
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Yea but I think that's a bit extreme. Only use it if the singer can't be far enough. If he or she tends to move closer to the mic one probably just don't hear the vocal track well enough...
OT - how do you distance yourself? | Stig Eliassen | General Discussion | 19 | 10-27-2010 03:43 AM |
USB distance | DannyG | Pro Tools TDM Systems (Mac) | 6 | 06-14-2009 10:45 AM |
Out there, in the distance... | cinetj | Post - Surround - Video | 6 | 07-28-2008 08:45 AM |
Max distance PT - Mac? | diegogat | Pro Tools TDM Systems (Mac) | 1 | 05-28-2003 11:26 AM |
Getting Some Distance Between the Noise and You? | tomhartman | Pro Tools TDM Systems (Mac) | 12 | 01-06-2002 02:54 AM |
