Old 10-17-2017, 10:50 AM
sodastereo sodastereo is offline
Default FXs on vocals
When I mix vocals I usually use an EQ, one compressor, a second compressor, and a Deesser, plus some compression and eq in the vocals channel. But I’ve seen people put a thousand plugins in vocals, which makes me think, am I doing something wrong??
Enviado desde mi iPhone utilizando Tapatalk
Old 10-17-2017, 11:49 AM
Inglesworth Inglesworth is offline
Default Re: FXs on vocals
I've seen people mix and in doing so press every damn button and twist every damn knob there is. And I've also seen people mix, and use the volume fader and some panning only.
I've also used both of these approaches myself at one time or another.
It really depends on the source material you are starting with, and how it is interacting with the other elements in your mix.
If it sounds good... it is good.
Old 10-17-2017, 12:00 PM
Raoul23 Raoul23 is offline
Just do what you have to do to make it sound good. There is no right or wrong way for a sound to sound
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 10-17-2017, 01:31 PM
There's no need to use a plugin or set of plugins because you see someone else do that. Some do that because it works for them; some do that just because they can do that which is never a good reason. On vocals - going in I never use eq, preferring to get the sound needed via mic choice. Maybe a light compression but that's it.
Jack
QAPLA!
Old 10-17-2017, 01:40 PM
Yep, if it sounds good, it IS good My chain is (usually) first insert is empty(in case I need Melodyne)>EQ III>BF76>Smack!>Puigtech EQ1A. Sometimes I add a de-esser, but mostly I do that manually on the track(with Clip Gain or an Audiosuite EQ). Sometimes I will add Waves Vocal Rider at the top(once Melodyne is done and committed). Some of this will change now that I added softube's Console 1, and the first EQ gets swapped for Slate VMR when I use the Slate mic on vocals(usually track with Miktek CV4, or C7)
Old 10-17-2017, 04:00 PM
amagras amagras is offline
Oh man, I love the BF76! It's great to hear others are using it as well
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 10-17-2017, 06:39 PM
Its just doing 2-3db of reduction. Actually, this thread is not really named correctly as we are all talking about "processing" and not FX, which usually refers to reverb/delay and such Sometimes I will drop in the Waves JJP vocal plugin and delete everything else
VOCALS on the 11R? MyerzMedia Eleven Rack 5 03-16-2011 06:41 PM
help! with vocals aztlan2010 Pro Tools TDM Systems (Mac) 2 04-24-2010 10:01 AM
Breathy vocals and vocals in general rckandorroll Tips & Tricks 3 01-30-2007 10:13 PM
Breathy vocals and vocals in general rckandorroll Tips & Tricks 5 01-30-2007 10:10 PM
Any tips on blending old vocals with new vocals? Somebody Pro Tools TDM Systems (Mac) 5 06-07-2000 08:38 AM
