Old 10-17-2017, 08:45 AM
Default Re: Should I record everything clean?
Things to consider:
#1-tracking with plugins doesn't "print" the plugins(the plugins are processing the audio AFTER its recorded)
#2-you CAN bus your tweaked audio to another track and record it WITH the processing(but as said, be sure you like what you hear)
#3-I use hardware compression while recording, but I keep it very gentle.
#4-there is no RULE on this stuff, only suggestions
Back to #1 for a moment, when I track bands, I have lots of plugins going, and most(if not all) will still be in place when I go to mix. They will probably get some tweaks(especially EQ's) and several more plugins will be enabled(I don't track thru some plugins due to the amount of latency, but I love them in a mix. Example: Waves JJP signature or iZotope RX for de-buzzing noisy guitar tracks)
Old 10-17-2017, 09:41 AM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by albee1952 View Post
Example:....or iZotope RX for de-buzzing noisy guitar tracks)
Nice I will try it !
Daniel
Old 10-17-2017, 10:45 AM
EGS's Avatar
EGS EGS is offline
Great advice from all above !!!
Personally, I record with no processing. I do monitor with plugs from the get-go, and tweak plug settings as needed during tracking/mixing. I have templates of plug chains that work for me, so I can get good sounds quickly. If I need to punch-in at a later date, I only need to match mic, pre, and placement.
My 2 cents !!!
Click for audio/video demo
Click for resume
Old 10-17-2017, 01:42 PM
"If I need to punch-in at a later date, I only need to match mic, pre, and placement"
That "2 cents worth" is worth $1K, all day long
Old 10-17-2017, 02:57 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
When a singer wants compression, I split the mike and record both with and without. While there is a lot to be said for committing, the most convincing settings often depend on everything being in place.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
record / mix clean electric guitar gianmetalbass Tips & Tricks 11 07-30-2013 01:41 PM
Clean through XLR thegreyfox Eleven Rack 2 01-08-2012 08:26 PM
How to clean KrisHeinold General Discussion 5 12-19-2010 12:58 PM
how do i clean this up? mojovoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-26-2007 11:04 PM
Clean up??? Eric_J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-25-2006 05:50 PM
