Should I record everything clean?
Is it wrong to record audio with outboard effects such as a channel strip? Or should I record clean and add compression eq and so on later in my DAW?
Enviado desde mi iPhone utilizando Tapatalk |
Re: Should I record everything clean?
A lot of guys are still recording through their analog recording consoles to get the sound of the analog systems. Other prefer to record everything completely clean and then add whatever analog saturation in post. Adding EQ and compression is sort of a this or that equation. If you EQ the recording on the way in, then you can't undo it. Likewise with compression. It just depends on what you are going after and how much flexibility you want.
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
I usually do, but agree with the previous post on what you are doing. You can always experiment prior, which sometimes just test it out with a mock session or something if you are not experienced with this type of thing. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.5, DP 11.3, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
If you know what you are doing/want you can record through whatever you want, just make sure you don't change your mind after. I personally tend more and more towards getting the song right on the recording even if that means tracking through hardware effects I won't be able to bypass later. Before, I used to craft/plan my mixes after the songs were recorded, it never really worked.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
I would just never go overboard with any outboard. Kiss that threshold go easy with the GR. Don’t cut too much with EQ...just be easy with it. So when you get to PT there is still some wiggle room. All major drum process for me are done in PT. All parallel processing’s well. But everything else is open season.
Super important
what does "kiss that threshold" mean? "go easy on the GR", whats that? |
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
There are a few things I would use compression on on the way in: piano, singers (unless they have really excellent self level control), and drums. All with a low ratio like 1.5 to 1 and just enough threshold to get a dB or two gain reduction. If I ever have to track a metal drummer who hits like Thor's hammer then a limiter would be in the chain.
And this brings up an interesting point at least for me: self level control by the person in front of the mic whether it be singer, guitarist, whatever. A good one will never need much compression if at all; witness Frank Sinatra. Legend is the engineers on his session never used compression on the way to tape because he had such good level control. Another reason for not compressing heavily on the way in is the mic will pick up everything going on and make it heard all the more easily making it more difficult to fix after it goes to 'tape'. Chair squeaks, jewelry tinkling, breath noises, etc. EQ on the way in? Never. I'll change mics and/or mic patterns before doing that. |
Thats easier to understand. |
record / mix clean electric guitar | gianmetalbass | Tips & Tricks | 11 | 07-30-2013 01:41 PM |
Clean through XLR | thegreyfox | Eleven Rack | 2 | 01-08-2012 08:26 PM |
How to clean | KrisHeinold | General Discussion | 5 | 12-19-2010 12:58 PM |
how do i clean this up? | mojovoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-26-2007 11:04 PM |
Clean up??? | Eric_J | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-25-2006 05:50 PM |
