Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-25-2015, 07:45 AM
smd1000 smd1000 is offline
Default Video Won't play
Hello and help!
I've searched the forum and found nothing on this.
I'm running LE 8 on a 2x2.66GHz Dual-Core intel Mac w/5GB ram and my video simply will not play -- very vexing.
I've tried multiple formats: all Quicktime / .mov: animation codec, H264 codec.
When I import the video, all is well, but when I play -- either with the transport or the space bar -- the video plays for one frame, then stops -- but the audio continues playing just fine, and I'm able to edit the session at will. The video is simply not playing. I've checked all the obvious things: the video is online, the timecode is the same as the session (however, the frame rate is not -- I do not have the option to change the session frame rate to the same as the video (29.97)). I even went into he prefs and selected high-priority video playback.
Anybody had this problem? Any ideas?
Thanks!
Old 01-25-2015, 02:24 PM
Craig F Craig F is offline
Default Re: Video Won't play
covert it to something better than h264
mpeg, photo-jpeg, or DNxHD36
Thank you,
Craig
Old 01-25-2015, 03:25 PM
Thanks! I got this problem solved thanks to Peter P. on Elance:
This was a known PT 8 bug that was remedied with an update. Updating to 8.0.5 at the link below should do the trick. http://avid.force.com/pkb/articles/e...cType=1450#PT8 (If you're on a crack and this isn't feasible, some have tried a workaround by downgrading their version of Quicktime. You may even have an older version of Quicktime hiding in your utilities folder that you can use.)
I knew it had to be something simple.
Old 01-25-2015, 03:31 PM
h264 is still a CPU hog
Thank you,
Craig
Video won't play THStudios Pro Tools 10 2 01-10-2012 11:36 AM
How do you play a video thru your interface? obidon Pro Tools TDM Systems (Mac) 8 12-10-2011 09:35 AM
Video Doesn't Play facher83 Pro Tools M-Powered (Win) 4 07-23-2010 03:39 PM
Video Won't Play in 8.0.3 PoppSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-26-2010 07:37 PM
Can't play Quicktime video through the V10 mrchoche Pro Tools TDM Systems (Win) 1 02-07-2007 05:26 PM
