Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 02-13-2015, 10:16 AM
pribb1 pribb1 is offline
Default "Current playback engine does not support a sample rate of 48 khz"
Just upgraded from PT8 LE to PT11.
Every I try to open an existing session, I get the following message: "Current playback engine does not support a sample rate of 48 khz". So I can't work any old sessions. Anyone know how to fix this?
Thank you!
Specs
Operating System: Windows 8.1 64-bit
CPU: 4th Gen (Haswell) Core i5 3.5GHz
Graphics/Video: Intel HD Graphics 4600
Maximum Resolution: HDMI: 4096 x 2160 @ 24 Hz, 2560 x 1600 @ 60 Hz; DVI-D: 1920 x 1200 @ 60 Hz; VGA: 1920 x 1200 @ 60 Hz
Memory – Included: 8GB DDR3/1600 (4 slots/2 filled)
Plus: 2 4GB1600 - Lifetime Memory PC3-12800 DIMM 4GB
Plus: 1 InstallRAM - Install: 4gb1600
Memory – Max: 32GB (install in pairs)
Storage – Included: 1 TB Seagate Barracuda (SATA 6.0 Gb/s)
Optical Drive: DVD-RW
USB Ports: 4 x USB 3.0 ports (4 rear); 4 x USB 2.0 ports (2 rear, 2 front)
PCI Slots: 1 x PCIe 3.0/2.0 x16 (x16 mode, gray), 3 x PCIe 2.0 x1
Old 02-13-2015, 10:18 AM
Default Re: "Current playback engine does not support a sample rate of 48 khz"
And I have a Roland Quad Capture.
Old 02-13-2015, 10:22 AM
Top Jimmy's Avatar
You don't mention what audio interface you are using. If windows is using your audio interface, the sample rate can't change and pro tools will give you the error you received. Switch windows back to using onboard audio and pro tools shouldn't have this problem anymore unless it's a third party interface and you need to change the sampling rate before opening pro tools.
James Cadwallader
Old 02-13-2015, 10:33 AM
I'm a relative newbie, so excuse my limited knowledge. The audio interface I'm using is the Roland Quad Capture.
How do I change the sample rate before opening Pro Tools?
Old 02-13-2015, 10:45 AM
hooksound hooksound is offline
Hey pribb1.
Sounds like your default Windows Playback device is set to use your audio interface. This was OK in pre-PT11, but the new audio engine in PT11 does not seem to like this.
Old 02-13-2015, 10:51 AM
So what should I do?
Old 02-13-2015, 11:02 AM
Hmm, I'm on Windows 7, so it might look a bit different in W8. In W7 there's a little speaker icon in the lower right notification area of the desktop. Right click the icon and select "Playback devices". It should also be accessible via the Control Panel under "Hardware and Sound". Select something else than your audio interface and click "Set Default". Then try to reload your PT session.
Old 02-13-2015, 11:48 AM
mesaone mesaone is offline
It's the same exact process in Windows 8.1.
You might have to do it for default recording device, as well. And make sure you restart, just in case.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 02-13-2015, 02:38 PM
mesaone - How do I change the default recording device?
Old 02-13-2015, 02:56 PM
Same way you do it for the playback device, only you choose the Recording tab instead of the Playback tab.
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
The current playback engine does not support a sample rate of 48 kHz oNeKOG Third Party Interfaces 3 09-08-2014 04:36 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
"The current playback engine does not support a sample rate of 48 KHz" E-Lister Windows 3 02-25-2012 11:54 AM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 03:17 PM
