#81
Re: Focusrite Scarlett Interfaces - New MixControl and Driver Betas July 2014
From the DUC it got the impression that, although Focusrite is apparently still battling driver issues with PT on PCs, their stuff works OK on Macs. Are you saying that it really doesn't there either?
#82
I finally found a solution to the Focusrite issues!
Picked up my Steinberg UR44 30 minutes ago! |
#83
Integral guitar effects - includes Cubase AI too! Bye-bye Focusrite and PT?
#84
Re: UPDATE: Focusrite Scarlett Interfaces - New MixControl and Driver Betas July 2014
Last week I upgraded to Pro Tools 12.3. What I discovered this morning is that if I need to change the sample rate going from session A to session B, then all I need to do is close down Pro Tools, open MixControl, change the sample rate to whatever the new session will be (44.1k or 48k), then reopen Pro Tools, open the new session.
If you forget what sample rate you need and open a session with a different sample rate than the the MixControl is set at, you no longer have to reboot and all crap like before. Just close the session, and rinse and repeat the above procedure. I did exactly that this morning and it worked fine. No longer have to use the work-around switching to a dummy session and going to the ASIO4ALL and all that rot. Not sure what changed in PT 12.3, but that's the current state. It may also work this way for ANY version of PT 12...I don't recall that I tried opening any sessions in a different sample rate since I upgraded to 12 a month or so ago, but for SURE it works this way with 12.3 I have NOT changed or updated ANY of the Focusrite software since I upgraded to Pro Tools 12. Just thought I'd pass this along for anyone still having this issue. Much better!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
eLicenser Control (eLC) updated to Version 6.7.1.8151 – released July 14th, 2014 | unkJE | Virtual Instruments | 0 | 07-14-2014 06:37 PM |
Focusrite LS56, MixControl freezes | rofa | macOS | 8 | 05-05-2014 02:07 PM |
Distortion between Focusrite MixControl and PT9 | pearldrum944 | Third Party Interfaces | 11 | 03-05-2014 01:57 PM |
Focusrite Scarlett 2i2 Driver issues in Pro Tools 10 | jeremyguy | Windows | 8 | 10-02-2013 08:54 AM |
Focusrite RTAS MixControl | DannyG | Pro Tools 9 | 1 | 11-23-2010 03:24 PM |
