#71
Re: Sample Rate and H/W Buffer negotiation woes.
I mean... I literally explained how to do that known process step by step, and now it's something he claims to have developed.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#72
Wow he developed that? I've been using that for years.....he must consult for avid,
#73
Hi guys,
was checking out this thread and was wondering if any of you managed to get this problem sorted? I seem to be having some of that trouble too, but i use an SPL Crimson...its a disaster! clicks, pops, distortion at times and cannot change sample rates without pro tools acting up on me...asio buffer sizes only operate properly if set when pro tools is reopened... I was going to buy the iD22, but id like to know from you guys if im doing the right thing here...considering that i have been having a huge nightmare with the SPL crimson...the fact that pro tools jams and stops responding and distorts at time and does not play at all at 32bit buffer size is a big problem for me... Im using an i5, 16gb ram desktop with windows 7 64bit on pro tools 10 and 11...any help/suggestions would be much appreciated. thank you |
#74
Does PT work OK with larger buffers? What sample rate are you using?
I haven't seen any improvements in how PT handles any of my ASIO interfaces. Those that dominate/control the DUC apparently trumpet AVID's attitude that all of the problems are the fault of the interface manufacturers (even though those manufacturers design their interfaces to ASIO specifications to ensure compatibility with DAW software). Focusrite seems to still be struggling (for at least the past year now) with their Beta ASIO drivers for their Scarletts to work properly with PT. No other manufacturer (except possibly RME) appears to be bothering with that. From what I've seen on the DUC, the RME interfaces seem to work best with PT on PCs (though nobody has yet said that they report their latencies properly so PT can correct for their record latency properly). Seemingly all other interfaces (including AVID's) require workarounds, compromises, and/or have "stability" problems. Quote:
Last edited by Amack; 08-08-2015 at 06:26 PM. Reason: Add larger buffer, etc. questions |
#75
Bump with an update. I bought an excellent little USB-powered headphone amp that has pretty good ASIO drivers. I've been using it for about 6 months, ever since 12.2.1 with zero issues until I upgraded to 12.5.
It works well in multi-client mode (as in both PT sound and OS sounds play through the same device with no fuss) But it worked a lot better on 12.4 than it does on 12.5. When using 12.4, Pro Tools was able to take control of sample rate and buffer size. With 12.5 it can do neither. Pro Tools will throw AAE errors or outright crash if the device is not set to the session sample rate ahead of time. 12.4 could change the buffer size and sample rate at whim. I am not happy about this, to the point that I just rolled back to PT12.4. Quote:
Okay, this is extremely frustrating. PT works fine when I set the interface sample rate to the project sample rate first, then open the project. But any projects I open after that will crash PT. Same sample rate, different sample rate, it doesn't matter. It just crashes. Instead of rolling back to 11.2.2 I'm just going to uninstall Pro Tools and use Reaper from now on. I need my DAW to work, and I can't afford to troubleshoot it for 2+ hours every time I switch playback devices.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB Last edited by mesaone; 04-27-2016 at 11:49 PM. |
#76
I haven't even read all the posts here, but this behavior is typical for me with both of my interfaces. I loved the 003+ where I could change sample rates & buffer size in Pro Tools, but the interfaces I have now sound better, so I can deal with having to restart Pro Tools when changing those settings. Not a huge deal for me as I'm used to it. Would be nice not to have to though.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#77
Its better now than it used to be which often required rebooting not just PT, but the entire system!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#78
Can you change H/W Buffer Size from within PT without the need to quit PT?
No. Need to use their Control Panel and shut down PT. Which audio interface did you use for these questions? Native Instruments Komplete Audio 6 Which OS and version, PT version, etc. Windows 10. Pro Tools HD 12.5 See it in video form here KOMPLETE AUDIO 6 - UNBOX, SETUP, RECORD (look in Description and go to the Using with PT segment)
003R+ & PT11 sample rate & buffer issue. | Nialzzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2014 11:21 PM |
003R+ to PT11 sample rate & buffer issue | Nialzzz | Pro Tools 11 | 0 | 01-11-2014 12:53 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Unable to change sample rate or buffer size with 11R | MattBaron | Eleven Rack | 5 | 03-05-2012 03:39 PM |
sample rate and buffer, help | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-08-2006 08:22 AM |
