Old 07-08-2014, 02:43 AM
pericoloso pericoloso is offline
Default Move/copy multiple plug-ins to other insert slot at once
Hi all,
Is there a way to move the inserts on slot A to slot B for multiple tracks at once? Or to copy all the inserts on slot A to slot B?
I know you can move/copy them one by one, by dragging/Alt + dragging, but this can be tedious if a whole row needs to be moved.
Ideas anyone?
Kind regards,
Mac Pro
Mac OS X 10.9
Pro Tools 11
Pro Tools|HDX2
Avid HD I/O 16x16 Analog
Avid HD Omni
Old 07-08-2014, 09:19 AM
Default Re: Move/copy multiple plug-ins to other insert slot at once
I am not aware of any way to do this. I suggest either a change in workflow, or create session and track templates to cover your needs.
Old 07-08-2014, 09:27 AM
The Weed's Avatar
The Weed The Weed is offline
Duplicate the track?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-09-2014, 12:55 AM
I don't see how duplicating the track moves down the inserts...
Mac Pro
Mac OS X 10.9
Pro Tools 11
Pro Tools|HDX2
Avid HD Omni
Old 07-09-2014, 05:44 AM
Stig Eliassen's Avatar
Not aware of any way to do this.
I always instantiate the first plugin/send in slot B, for 2 reasons:
1) I use an ICON console, and the lower row of encoders are closer to me
2) I have the option to put a plugin at the top of the chain without moving the other(s)
Old 07-09-2014, 05:57 AM
Valid points, but on an ICON you can do
- Do To All Selected
- Copy the plug-in to another slot
Right?
There should be something like this in Pro Tools.
Mac Pro
Mac OS X 10.9
Pro Tools 11
Pro Tools|HDX2
Avid HD Omni
Old 07-09-2014, 06:53 AM
sw rec sw rec is offline
Alt-click each one and drag to the desired track. How long can that take??
Old 07-09-2014, 07:08 AM
Read the original post, I know that you can drag them one by one. That was not the question.
For 700-track projects, changing plug-in order one by one is not the ideal way to go for people who are not retired yet.
Mac Pro
Mac OS X 10.9
Pro Tools 11
Pro Tools|HDX2
Avid HD Omni
Old 07-09-2014, 09:41 AM
Originally Posted by pericoloso View Post
Hi all,
When I need to do this I'll save the session, do a 'save as', and then import data from the previous session onto the new target tracks importing inserts and insert settings only.
It would be nice if one could simply copy and paste but it doesn't exist right now.
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 07-09-2014, 10:01 AM
Drew Mazurek's Avatar
Track Presets are likely coming soon. The basics are already there using the .ptxt suffix to convert session files to track presets. This was developed by Avid for Pro Tools Express.
http://www.pro-tools-expert.com/home...ls-11-mac.html
Obviously doesn't help much in this case, but signs of hope for the future!! :)
www.drewmazurek.com
Insert time; 1 track don't move Nayon Getting Started 5 06-19-2014 09:16 AM
Insert measure -> move tempo-bpm etc. AJF Pro Tools 10 5 06-01-2012 10:35 PM
Copy a plug-in to multiple tracks? tokolosh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-23-2009 05:09 AM
copy/pasting insert plug ins jmallen Pro Tools TDM Systems (Win) 3 06-14-2006 01:59 PM
no digi power after PCI slot move?? GrahamCA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-30-2002 04:25 AM
