Old 09-03-2015, 01:30 PM
mrtomcat mrtomcat is offline
Default EUCON 3.3 crashes every time when launching PT 12.2
I had zero issues in PT 12.1 with Eucon 3.3 but now with PT 12.2 every time I launch it Eucon crashes. I then relaunch Eucon and everything works.
Anyone else has that issue?
Bug Report: http://protools.ideascale.com/a/dtd/205961-3779
PT Ultimate 2021.10
Nuendo 10.3
Wavelab Pro 11
UAD Satellite Octo Thunderbolt, UAD Quad Pcie
Apollo Twin Duo,
HDX Card,
2x Avid I/O Analog 16/16,
4x Artist Mix, Avid Dock, PT Control,
2019 Mac Pro 12 core, 48 gig Ram, running Big Sur,
lots of outboard gear
Old 09-03-2015, 01:31 PM
simonjewel's Avatar
simonjewel simonjewel is offline
Default Re: Eucon 3.3 crashes every time when launcing PT 12.2
Yes, exactly the same here, driving me nuts!
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11.
Old 09-03-2015, 03:57 PM
simonjewel's Avatar
I have been on the phone with tech support for the last couple of hours on this issue ... There is a bug that is relevant specifically to VCA master faders by the look of it ... Has anyone noticed that the VCA's have input monitoring and record enable buttons? This should be reported as a bug today by Avid tech support ... Workaround for now, is to not use VCA's apparently, lets hope it gets fixed asap :)
Old 09-03-2015, 04:27 PM
Interesting. I have HD so VCA's are my daily must haves... going to check on that when I get back to the studio. Might have to roll back to 12.1 especially since there is nothing new for us HD peeps anyway, sigh
PT Ultimate 2021.10
Nuendo 10.3
Wavelab Pro 11
Apollo Twin Duo,
HDX Card,
Old 09-03-2015, 05:58 PM
tonepad tonepad is offline
Yep seems buggy...I've had the crashes and then even the crash window showing which I can then dismiss and it goes on working OK. My biggest repeat issue is closing a PT session, quitting and relaunching with the Eucon not responding to the relaunch. I have to the use the "restart Eucon apps" option...which I've had to do in the past...mostly I think because I stress it with "removing" and "claiming" it between a Mac PT HD rig and a Win7 plain rig. I've grown used to the tweakineess of that but this is ONLY on the Win7 PT vanilla box...keeping the Mac quarantined for now.
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 09-03-2015, 06:00 PM
Default Re: EUCON 3.3 crashes every time when launching PT 12.2
I should mention that in this config I use an Artist Control and Mix, but sometimes only the Control surface.
My day job:
Wilson Dyer MPSE
Old 09-03-2015, 07:41 PM
you were correct the VCA faders in 12.2 are broken...what in the world?
Anyway, rolling back to 12.1 until this is fixed.
Makes you wonder who does their QA and UAT...unbelievable
PT Ultimate 2021.10
Nuendo 10.3
Wavelab Pro 11
Apollo Twin Duo,
HDX Card,
Old 09-03-2015, 10:30 PM
actually I stand corrected on the VCA's they always had the input monitoring and record buttons...they just don't do anything... I rolled back to 12.1 and even looked at images of older versions and there they were...
Anyway, still hoping they will fix the eucon crash sooner than later
PT Ultimate 2021.10
Nuendo 10.3
Wavelab Pro 11
Apollo Twin Duo,
HDX Card,
Old 09-03-2015, 11:19 PM
P_J P_J is offline
Here too, every time when sessin is opened. Started after 12.2 update. After crash, reopened Eucon is solid.
Old 09-03-2015, 11:45 PM
correct when the session is opened, not when pt launches.
I first thought it had to do with layout settings I had saved for the session and re did them, but no go.
PT Ultimate 2021.10
Nuendo 10.3
Wavelab Pro 11
Apollo Twin Duo,
HDX Card,
Standalone Editor Crashes Every Time When Launching No Matter What Aztechuhs1 Eleven Rack 1 02-08-2015 11:55 AM
Crashes while launching the last plug-in tobbenos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-01-2010 01:20 AM
6.4 crashes when launching on new pc Minimalism 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-13-2009 02:51 PM
Argh Help! PT 8.03c not launching, crashes every time Worship Factory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-15-2009 03:29 PM
7.4.2 crashes when launching whylago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-28-2008 04:00 PM
