"Copy to Send" bug on freezed tracks
If I had a freezed track and make the "copy to send" function I only get the "send fader" to -13.1
When I repeat it, it goes all the way down. Again back to -13.1 I dose not matter if a plugin is on that track or not. I happens on Aux also on Audio tracks. Also the channel fader can have any level point, the send fader goes only to -13.1 After unfreezing all works fine as it should. (PT 12.5.2, EC 10.11.5, Mac Pro 2008) I tried it with 12.5.0 / .1 / .2 ...all the same. Anybody else have this happened? |
Re: "Copy to Send" bug on freezed tracks
Thanks jeffro for the info and link!
"Alt+Cmd+H" doesn't work on freezed tracks | ilmalvaggio | Pro Tools 12 | 0 | 03-14-2016 03:59 AM |
Why send tracks to hardware outputs instead of "Master" track/bus? | gopher | Getting Started | 11 | 01-03-2014 12:12 PM |
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" | xfarre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2011 07:37 AM |
"Copy to send" function on PTM-Powered | matcorp | Pro Tools M-Powered (Mac) | 3 | 03-20-2009 05:28 PM |
"Save Session Copy" MUST copy AIIFF files??? | BHeller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-11-2001 12:33 AM |
