Ping Pong Delay
Hello,
i'm new to the forum and would like to say hello to everyone. I would like to know how to program a stereo Ping Pong Delay, from the Mod Delay plug-in, is it possible, if yes, could you please give me some values, say for a 90 bmp the delay alternates in stereo from one channel to the other in 8th notes, with several repeats. I heard it once, it was one of Live plug-ins (ping pong delay) but i wasn´t able to get the values. Thanks in advance for any help. best regards, Jorge |
Re: Ping Pong Delay
Howdy Do....
90 BPM.....that would be 333.33 milliseconds (ms) per 1/8th note. A 1/4 note would be 666.67 ms. On most delay devices there is a setting for the amount of delay in ms. On one side of the stereo delay set the time for 666.67ms. On the other side set it for 333.33ms. Set the mix blend for the fast side (333.33ms) higher in value (%) than the slow side. Equal depth settings, and feed back to start with. Then experiment. Got a BPM conversion (to ms) chart? Ping |
Re: Ping Pong Delay
Thanks Ping,
nope i didn't have a chart conversion. but from the numbers you provide i believe that i must use a long delay right? i'll use the protools plug-in Mod delay. i'll try your settings and tell you about it tomorow. thanks again mate. Jorge Portugal PT LE AM III OS X & 9.2 G4 733Mhz |
Re: Ping Pong Delay
hello here's a tip you guys might like for calculating your delay
60000 devided by your bpm gives you the delya in ms for a 1/4note delay happy math the audiojunky |
Extra Long Delay Stereo Ping Pong issue | arb232 | Pro Tools 10 | 0 | 07-24-2013 08:59 PM |
Ping Pong Delay - Pro Tools Video Tutorial | Kenny Gioia | Tips & Tricks | 14 | 06-02-2007 02:25 AM |
Audiosuite D-FX: chorus, Flanger, ping-pong delay? | lwilliam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-18-2007 04:44 PM |
Real Time PING PONG DELAY with bare bones LE | Sacred Spirit | Tips & Tricks | 0 | 05-14-2005 12:05 PM |
Ping-Pong Delay (TDM) | Compression Records | Tips & Tricks | 1 | 12-12-2000 02:39 PM |
