Old 04-01-2011, 07:37 AM
beasleymusic beasleymusic is offline
Default "The current playback engine does not support a bit rate of 48kHZ" M-powered 8
It seems like a pretty easy thing to do but I don't know how
These sessions used to open but I was hooking up my pod X3 and was having troubles so I changed some things in my computer but I don't know what I did to make the sessions not open. I am using a profire 2626 and Pro Tools M-Powered 8
Old 04-02-2011, 03:17 PM
jojo99 jojo99 is offline
Default Re: "The current playback engine does not support a bit rate of 48kHZ" M-powered 8
setup the sample rate for your audio board before opening PT.
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The Current Playback Engine Does Not Support a Sample Rate of 48Khz justus1900 Pro Tools 9 14 10-23-2012 01:45 PM
"The current playback engine does not support a sample rate of 48 KHz" E-Lister Windows 3 02-25-2012 11:54 AM
