Old 01-09-2015, 08:30 AM
EricWillhelm EricWillhelm is offline
Default Can't hear audio on record-enabled track with 'Low Latency Monitoring' selected
Okay, I KNOW this is going to be one of those "Oh right!" moments, and I've figured it out before, but for some reason it's eluding me at present. I'm using a 002 rack with PTHD10.3.9 Native on a Mac, and when I choose Low Latency Monitoring, I can't hear audio on the record-enabled track. What am I overlooking? Curiously, in the manual, I see all this stuff about Low Latency Monitoring options (Enable the Low Latency Monitoring pop-up menu etc). But when I try to do what it says, those options are not even there. See linked photo...
https://dl.dropboxusercontent.com/u/...3AO%20shot.png
Love,
john Q. Idiot
Old 01-09-2015, 08:48 AM
Southsidemusic's Avatar
Default Re: Can't hear audio on record-enabled track with 'Low Latency Monitoring' selected
Hey
I think you need to have the input monitoring button (green "I") enabled to hear the LLM signal but I am not 100% sure. Maybe try that and see if it works
Best Regards
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 01-09-2015, 09:11 AM
For me, I stopped using LLM after it was broken in some previous version(I think it was PT9). I just set the buffer to 64 for tracking.(besides, I needed plugins and sends to work during tracking here).
Tried that. No dice. It looks like it might have to do with having a v11 driver, which I used when demoing v11. Now I'm trying to figure out how to revert.
Old 01-09-2015, 11:51 AM
Well, my problem was solved by un-installing and re-installing PT10 and it's v10 drivers for 002. Now Low Latency Monitoring is once again working as advertised.
Old 01-09-2015, 07:09 PM
Eric Lambert's Avatar
Out of curiosity, which version of PT? Is it 10.3.9?
Old 01-10-2015, 12:34 AM
bashville bashville is offline
Also I heard you have to be careful about having different named busses accessing the same hardware outputs. Sometimes sequences inherit multiple bus setups switching from room to room. So you'll have "Main Out" and "A 1-2" and "Output 1-2" all going out of the main outs, and it somehow messes up how LLM directs signal to the low-latency outputs.
HD Ultimate (HD Native), PT2019.12, OWC PCI-ext. TB2, Blue 192, 2018 MacBook Pro, 32 Gig, Mojave 10.14.6
Can't hear microphone when Low Latency Monitoring is enabled Ferrante Windows 7 12-11-2012 03:50 AM
ADC Audible Latency When ANY Instrument Track Is Record Enabled Intransit Pro Tools TDM Systems (Mac) 13 09-15-2011 03:07 AM
MIDI Input Problem - Selected Track vs Record Enabled salmonsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-28-2008 07:42 AM
no audio playback when track is record enabled indoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2008 06:02 AM
Cant hear record enabled track during playback michaiel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-19-2005 01:59 PM
