Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 06-12-2020, 08:45 AM
SomeOtherGuy SomeOtherGuy is offline
Default DADman MTRX profile question
I've saved my DADman MTRX profile and it loads each day on startup.
If I open a Pro Tools session with a hardware insert EQ on line inputs/outputs, the DADman switches this insert to mic level and I then have to go in and switch it back to line level.
All other settings are recalled correctly except for this. Any idea how to fix this?
Thanks.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 06-12-2020, 09:46 AM
creativecontrol's Avatar
Are you also actively using PRE protocol via IAC in Pro Tools peripherals to communicate with the MTRX preamps?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-12-2020, 09:53 AM
Default Re: DADman MTRX profile question
Yes, as such: (maybe I need to hit the reset button?)
Old 06-12-2020, 10:06 AM
Can you please give this a test and let us know if it’s what you are experiencing? Thanks.
https://avid.secure.force.com/pkb/ar...s-In-Pro-Tools
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-12-2020, 11:45 AM
That's it, it's the bug you mentioned. Closing and reopening fixed it.
This is a troublesome bug since you have
line level hardware suddenly patched through at mic level, causing an extreme increase in volume and distortion.
I see Avid has recognized the bug workaround back in January. Any idea when this might be fixed?
Thanks for alerting me to this.
Old 06-12-2020, 11:47 AM
Thanks for confirming. Would you mind opening a case and then I can reference your case number and get the issue escalated so we can get the bug squashed?
https://avid.secure.force.com/pkb/ar...-Case-Creation
Thanks,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-12-2020, 12:01 PM
Done. Case #03963888
Thanks Jeff.
Old 06-12-2020, 12:02 PM
Thanks. I’ll light a fire.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-12-2020, 12:04 PM
Thanks Jeff. If you might also take a look at my other long-standing open case #03559541, would greatly appreciate it.
Old 06-12-2020, 12:08 PM
Will do when I’m back in the office on Monday.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX Reference (Ref) Button in DADman Software jb_trm Pro Tools | MTRX & MTRX Studio 5 05-25-2022 02:08 PM
DADman .dms vs .dmprof file question Rich Breen Avid S4/S6 15 03-16-2020 03:04 PM
DADman/PROmon on MTRX with OSX above 10.12 Sierra paulo m Pro Tools | MTRX & MTRX Studio 4 03-01-2019 04:05 PM
S6 & MTRX question its2loud Avid S4/S6 8 01-21-2019 09:40 AM
Sum and Intercancel between MTRX DADman and S6 laki Avid S4/S6 1 12-27-2017 04:18 PM
