using mBox as audio output for iTunes
I'm using Pro Tools Le 7.0 on a Mac, Tiger installed. I'm trying to let the output signal coming from iTunes but going nowere. In the audio panel I've set the output to the mBox but nothing happens. Does anyone have any idea? Thanks in advance Best Regards
Angelo Andina Italy |
Re: using mBox as audio output for iTunes
Do you have the Core Audio driver installed?
With your Mbox connected, launch the Digidesign CoreAudio Manager (should be in the Digidesign folder in Applications).
Check the 'Status' - if it says 'not connected' click the connect button, then re-launch iTunes - that should do it. Buona fortuna! |
Can't use 002R with iTunes as an audio output | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-17-2010 11:23 PM |
iTunes audio output through Digi hardware? | Audiodude | Pro Tools TDM Systems (Mac) | 3 | 05-17-2006 10:13 PM |
iTunes audio thru Mbox? | Tony Moore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-14-2005 06:51 AM |
using iTunes with Mbox and Core Audio | aandina | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-19-2004 09:30 AM |
Using Mbox Core Audio for iTunes, FCE, GB, etc. | benom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2004 11:28 AM |
