Old 03-18-2024, 05:56 PM
mrguitarguy mrguitarguy is offline
Default Automatically Control Target Plugin
Is it possible to have your custom map for a plugin pop up automatically when opening a new plugin? My SSL UC1 automatically maps to the active SSL channel plugin and it's great! Click the plugin you want to control and just start turning knobs.
I can't seem to figure out how to do this with my S1. For example if I have a plugin I'm work with using my custom mapping for my S1, and then I click another plugin on a different track, is it possible for those parameters to now appear since the S! is already in Insert mode?
Thank you very much for any help or insights. Apologies if this has been posted before, I couldn't seem to find an answer while searching.
Big Sur 11.7.4, Pro Tools Ultimate 2023.6, HD Native, 2010 Mac Pro 5,1 3.46ghz 12 core, 128GB RAM, Radeon RX 580, 970 Evo M.2, 860 Evo, and Angelbird SSD drives. All PT optimizations followed to the letter.
Ventura 13.2.1, Pro Tools Ultimate 2023.9, M2 Pro Mac mini, 32GB RAM, 1TB SSD.
Old 03-18-2024, 10:53 PM
tope d's Avatar
tope d tope d is offline
Default Re: Automatically Control Target Plugin
I haven't done this before, but I'll check and see similar cases and try it out then get back to you.
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-19-2024, 08:22 AM
EddieJones's Avatar
Yes, There are a few settings you need to make sure are set, see the attached. The ? is optional.
Old 03-20-2024, 03:39 PM
Thank you so much, Eddie! That worked great!
Artist Control opens plugin automatically. sixstringbob Artist Series 8 02-21-2022 05:43 PM
Plugin Automatically Disables itself ??? teacherman AAX Plug-ins 3 10-01-2020 04:48 PM
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 klyg Artist Series 2 02-29-2012 10:50 PM
How do I automatically insert a plugin on all tracks at the same time? Undertones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-29-2010 01:21 AM
Can Command|8 toggle a plugin target? dpdemo ProControl, Control|24, Command|8 2 05-06-2006 01:43 PM
