Old 12-09-2023, 12:46 PM
mikeyman's Avatar
mikeyman mikeyman is offline
Default connecting Artist Mix and the Avid Transport control
I have Artist Mix hooked up to the ethernet input on my computer .I am thinking of buying the Transport contoller If i have two ethernet inputs on my computer could i just plug the Transport control into the other ethernet input on my computer?Would they both work or do i have to use a router and use the same eithernet port for both?Thanks ,Mike
Old 12-11-2023, 09:53 AM
EddieJones's Avatar
Default Re: connecting Artist Mix and the Avid Transport control
Depending on your settings it may work...BUT it would be a lot more reliable on the same network...a dumb switch would be best. Unless you are also using Avid Control, in which case a small gaming router would be ideal.
https://www.amazon.com/TP-Link-WiFi-..._title_ce?th=1
Old 12-11-2023, 11:57 AM
mikeyman's Avatar
hello Ed
i am only using the Artist Mix
Old 12-12-2023, 09:14 AM
EddieJones's Avatar
hello Ed
But you said you were getting a Transport?
Old 12-12-2023, 09:27 AM
mikeyman's Avatar
oh yes sorry .I will have the Artist Mix and the Transport..just the two of them
Artist Transport not connecting to PC KeyplayerG Artist Series 3 08-07-2023 03:36 PM
Do you use Artist Control or Artist Transport? tlevine Artist Series 1 11-01-2017 05:51 PM
Need some help with Artist Control and Transport... Brian8377 Artist Series 0 04-16-2015 03:07 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
Using Artist Control with Artist Transport? GrievousAngel Windows 2 03-14-2012 03:29 PM
