Old 11-25-2023, 12:33 PM
DaveSkipton DaveSkipton is offline
Default Help: Avid Artist Mix is recognised in EuControl but then loses connection
Hi, I have a problem with my Avid Artist Mix controller that is recognised in EuControl software, but then drops out after about 2 minutes every time. It also drops out when I start up Pro Tools.
I've read as many threads on this forum about this problem but I can't seem to find any thread with the same issue, so starting this new thread.
I have installed the latest EuControl software on my MacBook Pro M1 2021:
EUCON_WorkstationUnifiedInstallMac_2023_11_0_121.d mg which I downloaded from my Avid account's download centre.
My setup is (as also listed in signature below):
Pro Tools Artist 2023
Apple MacBook Pro M1 2021
Ventura 13.4.1
16 Gb RAM
Solid state internal HDD
Audient ID14 USB Audio interface
Native Instruments Komplete Kontrol 49 MIDI keyboard
I've bought a separate USB3.0 Gigabit Lan ethernet connector (USB 10/100 LAN) to connect the ethernet cable to USB C so I can connect it to my MacBook Pro's port - I've tried all three ports but same issue.
For troubleshooting, I've checked other posts here on the forum on this issue and I've checked:
- In System Prefs > Network: USB 10/100 LAN is set to IPv4 Configured Using DHCP
- Starting up the Avid Artist Mix by holding Page< + Page> is set to use DHCP on the unit
- EUCON Control Surfaces is clicked active in Pro Tools > Peripherals
The strange thing is that my Avid Artist Mix is coming up in EuControl (after I restart the unit):
(attached screenshot: EuControl Avid Artist Mix recognised)
but then I get this error message in EuControl saying:
'Network error. Unable to connect the unit named "Artist Mix".
(attached screenshot: EuControl error message)
In another EUCON thread on this forum, there was a discussion on the correct ethernet cable type to use for EUCON, and from what I understood in that thread is that (especially for MacBook users), a normal ethernet Cat5e cable would work, and that it was not required to use a crossover ethernet cable - is this correct? I've bought 3 new ethernet cables in the last few days to try and make sure it's not a cable issue and this is the cable type I've bought:
RJ45 Ethernet Patch Lead Cat5e Network LAN Cable (normal, not crossover)
For all of these brand new three ethernet cables, I still have the same issue.
Would it matter that my USB3.0 Gigabit Lan ethernet connector (USB 10/100 LAN) is not 1000? I'm trying to get some feedback here from the forum before starting to buy new ethernet USB connectors to troubleshoot.
Thanks a lot if anyone would have any input on this, would really appreciate it!
File Type: jpg EuControl Avid Artist Mix recognised.jpg (21.9 KB, 0 views)
Dave Skipton
Ventura 13.4.1
16 Gb RAM
Old 11-26-2023, 05:02 AM
its2loud its2loud is offline
Default Re: Help: Avid Artist Mix is recognised in EuControl but then loses connection
If connecting directly to your computer and not a router you should try setting up the Artist mix with a static IP.
Make sure the correct port is selected in Mac Preferences>Eucon.
Do you also have an Ethernet connected to the computer for internet?
Old 12-04-2023, 07:19 AM
EddieJones's Avatar
Ventura 13.4.1
16 Gb RAM
What happens if you pull the power to the mix, not press the power button. And then ug it back in.
Sent from my SM-S918U using Tapatalk
Old 03-15-2024, 09:46 AM
Joxepo Joxepo is offline
I have the same issue as well, with the exact same window popping up.
I'm using an M2 Max Mac Studio and MacOS 14.2 Sonoma.
Did you get anywhere with this issue?
Thanks
Jox
Old 03-18-2024, 11:20 AM
EddieJones's Avatar
Originally Posted by Joxepo View Post
Thanks
Jox
How is it connected to the Mac and what does it go through?
Old 03-19-2024, 12:46 AM
Thanks so much for getting in touch.
It is directly connected through the only ethernet cable and slot that the Mac Studio has. It doesn't go through anything else, just a ethernet out from the Artist Mix into the ethernet in on the Mac Studio.
Eucon version is 2023.11. I have tried with an older version of Eucon but it was exactly the same issue.
The network settings on both the Mac and the Artist are DHCP (not manual, just automatic).
Any help will be greatly appreciated!
Old 03-19-2024, 08:13 AM
EddieJones's Avatar
We have found that putting a dumb small network switch in between helps with this issue. The ports on the newer Macs are not that forgiving.
Old 03-20-2024, 02:25 AM
Thank you, I've bought a network switch and I'll try it as soon as it gets here.
Old 03-25-2024, 04:38 AM
Hi Eddie, you were right, buying a cheap ethernet splitter did the job. The Artist Mix worked as soon as I connected it through the splitter!
Thank you for the solution.
Cheers
Jox
Avid S1 EuControl connection drop outs on macOS Ventura 13.1 melgares Avid S1, S3, Dock and Control App 4 01-06-2023 05:08 AM
Avid Artist Mix loosing connection when in touch mode stigc56 Artist Series 7 07-05-2022 10:08 AM
EuControl discontinued for Avid Artist Series? ALSTUDIOS Artist Series 10 02-17-2022 08:47 PM
Please Help! Avid Artist Mix Mac - No Connection RedEyeJedi Artist Series 6 07-25-2019 02:50 PM
Avid Artist Mix Series & EuControl Driver Ha s A Bug! shamanrock Artist Series 1 09-21-2015 09:58 PM
