Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Closed Thread
Old 11-10-2020, 12:50 AM
Akiz Akiz is offline
Default ProTools 2020.11
So there are some nice new features in next ProTools release.
What’’s New in Pro Tools 2020.11
New Features and EnhancementsPro Tools® and Pro Tools | Ultimate™™ software version 2020.11 provides the following new features and enhancements.
-UI Themes•• Pro Tools lets you change the theme for the User Interface (UI) between Classic (legacy) and Dark (new).
-Convert Audio to MIDI•• In partnership with Celemony, Pro Tools integrates Melodyne™™ to enable audio pitch and amplitude conversion to MIDI notes and velocities.
-Space Clips Command••The Space Clips command sets the space between selected clips on the timeline by a specified amount in the selected timebase.
-Bounce Mix•• Bounce Mix (formerly Bounce to Disk) lets you export your mix, including sub-mixes, to multiple file formats without having tocreate extra dedicated audio tracks in your session for bus recording.
-Import QuickTime, AAC/M4a, and MXF OP-1a Audio•• Pro Tools lets you import audio from QuickTime, AAC/M4a, and MXF OP-1a files without having QuickTime installed on your com-puter.
-Import and Export AAF Mute State•• Pro Tools supports import of static track mute settings in an AAF created from Avid Media Composer 2020.9 and higher. Pro Tools automatically includes mute settings when exporting selected track as AAF.
-Bounce Mix to MOV (Public Beta)•• Pro Tools provides a Bounce Mix to MOV (Public Beta) option. This lets you transcode video to new files along with PCM audio in mono, stereo, and 5.1 channel widths. This feature is offered as a public beta and is not fully supported at this time.
-Support for Up to 512 Master Faders(Pro Tools | Ultimate Only)•• Pro Tools | Ultimate supports up to 512 Master Fader tracks.
-Optimize Performance at Low Buffer Sizes Option(Mac Only)•• Optimizes CPU performance at lower HW Buffer Size settings.
Dolby Atmos Improvements(Pro Tools | Ultimate Only)
-ADM Import and Export•• Pro Tools | Ultimate lets you export to the Dolby® Atmos™™ ADM BWF file format using the Bounce Mix.•• Pro Tools | Ultimate provides improved import of ADM BWF files using Import Session Data.
-I/O Setup Improvements•• Changes to I/O Setup improve the interaction between Pro Tools and the Dolby Atmos Render and facilitate AMD export using Bounce Mix.
No ARA2 support for Melodyne, which i find weird since they use Melodyne engine for Audio to Midi feature. At least is a good start, hope next time will implement ARA2 as well...
Discuss.
Cheers!
Mac Pro 6.1 "Late 2013", 12 Core 2.7 Ghz, 32Gb Ram, 1Tb SSD, MacOs 10.14.6 "Mojave", Apogee Ensemble Thunderbolt, Softube Console 1,
Avid Artist Mix, Pro Tools Ultimate 2021.7.
Old 11-10-2020, 12:54 AM
Mark Ziebarth Mark Ziebarth is offline
Default Re: ProTools 2020.11
It seems like it’s improving...
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 11-10-2020, 01:15 AM
Nice. Bounce Mix will be handy.
I was hoping there would be some work to address CPU stability on Windows. Maybe that did not make the notice.
Old 11-10-2020, 02:03 AM
simonchase simonchase is offline
Where are you getting this from?
And I'm not sure I understand the new "bounce mix" feature. How has it changed?
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 11-10-2020, 02:15 AM
From the forthcoming release. Bounce Mix has a lot new features!
Bounce Mix (formerly Bounce to Disk) lets you export your mix, including sub-mixes, to multiple file formats without having to create extra dedicated audio tracks in your session for bus recording. Bouncing writes to separate audio files, so you do not have to reserve any tracks for a bounce. A bounce can be done offline (faster than real-time) or in real-time (so you can listen to audio playback of your mix during the bounce process).
You can use the Bounce Mix command to export loops, sub-mixes, stems, or any other session audio. You can use it to create final mono, stereo, and multichannel master files in any of several audio file formats. Bounce Mix also provides conversion options for sample rate, bit resolution, and format. It will even let you automatically import bounced files after the bounce is complete. Use Bounce Mix presets to store and recall your most commonly used Bounce settings.
Old 11-10-2020, 02:24 AM
Hmm, I’m with Simon. I still don’t get what is different with Bounce Mix...
I guess some real world examples will show what it’s good for.
Best
Mark
Sounds the same to me...???
I don't see a press release on line
Thanks for the info anyway
Old 11-10-2020, 03:16 AM
Emi's Avatar
Emi Emi is offline
Am I reading it right? it will integrate Melodyne?
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 11-10-2020, 03:21 AM
midnightrambler midnightrambler is offline
It'll just convert audio to MIDI. You know, like Logic's been able to do for something like a bazillion years.
Old 11-10-2020, 03:40 AM
Emi's Avatar
Emi Emi is offline
only for converting audio to midi. Wich is also welcomed for using drum sample...
This new version looks good
Closed Thread
Protools 2020 DAW midi controls? Red Solarflare Pro Tools 2020 4 12-11-2020 06:56 AM
Renewed Protools 2020 No downloads in account auratone Licensing & Accounts 4 10-08-2020 05:08 PM
ProTools 2020 HUI support courtsong Pro Tools 2020 2 10-02-2020 02:26 PM
Protools 2020 Mac Catalina Just Crashes JimmyD150155 Pro Tools 2020 12 05-02-2020 12:06 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
