Old 04-26-2020, 10:58 AM
zavid zavid is offline
Default Setting Up Pro Tools Control From A Laptop To A MacPro D.A.W.
Hi ,
here for ask if is possible install "Control" app on a Macbook pro
and connect it to a Mac Pro 3,1 by ethernet cable
(unfortunately no wi-fi on Mac Pro 3,1)
for control Pro Tools 10 HD 3 (pcie) from the Macbook pro ,
any info about is welcome ,
thanks in advance
cheers
Old 04-26-2020, 08:47 PM
Default Re: Setting Up Pro Tools Control From A Laptop To A MacPro D.A.W.
I don't think you can do it with what you have, but there are still some options:
1-To the best of my knowledge, the control app only runs on iOS(iPad, iPhone) or Android.
2-for connections, get a wifi router(dual band are preferred) and connect the iPad/tablet to wifi and run a cat5 cable to the ethernet port on the Mac Pro.
3-Install Eucon on the Mac and go into Pro Tools>Setup>Peripherals and check the box to enable Eucon.
4-there is probably a way to use the MBP with some form of desktop sharing, but I know little about Macs, so hopefully, someone else can offer insight on how to make that work.
5-depending on how far away you need control, you might also get away with a long USB cable to a spare keyboard and mouse. Then you could use a splitter to feed another screen(if you can use an HDMI connection, a 30' HDMI cable can be had for less than $50(I did this on a PC setup with a 50' USB extension to a small keyboard with a track pad and had the keyboard on a rolling cart with a monitor bolted to the top. It would just reach into all 4 of my recording spaces and worked perfectly(make sure the screens on the splitter run the same resolution). I ran a DVI to HDMI cable to the splitter(which was active and cost all of $35)
Old 04-27-2020, 12:22 PM
Hi ,
much thanks for the post !
the cable extensions with monitor and keyboard on a cart is the most solid way …
(… moreover the first way since pro tools 24 …)
any other help about are welcome
cheers
Old 04-28-2020, 11:05 AM
somebody have checked if "Control" work with a iOS emulator
"inside" / over the OSX ?
thanks
Old 04-30-2020, 11:35 AM
MrDibS MrDibS is offline
It’s a touch interface. There’s no way or reason to run it on a laptop.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6
PT HD Ultimate 2021.12 HDX with Focusrite Red 8pre, Rednet 2, R1, Dock + S3.
Old 05-05-2020, 09:09 AM
thanks for post ,
in case of no iphone , tablet , owned
why a laptop cannot remotely control a software ?
or is pro tools "controllable-manageable" from a tools like remote desktop ?
thanks in advance for any help about !
cheers
Old 05-05-2020, 09:34 AM
macOS has built-in screen sharing. I use it frequently to control Pro Tools from a laptop. Works fine if you have a decent bandwidth network.
EDIT: this is NOT using the Avid Control app, which I also use, but which isn't particularly convenient for playlist management, etc. when tracking.
Scott Gatteño
Old 05-05-2020, 02:44 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
+1
I do this all the time to be able to record in different rooms in the house and still control the PT HD rig in the basement.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 05-12-2020, 01:54 AM
Originally Posted by 29CountsNY View Post
+1
much thanks for post ,
about remote desktop tool
do you use "Cord" ?
cheers
Old 05-12-2020, 05:42 AM
29CountsNY's Avatar
No, all wireless over wifi.
It’s just a screen share so it’s pretty fast with not much latency.
www.29counts.com
Local Control setting issue with Yamaha Motif xf8 and Pro TOOLS 10 jeffj General Discussion 0 05-13-2014 10:08 AM
Upgrade on laptop but not macpro? OneMadSon macOS 3 01-30-2013 12:53 PM
Setting up a Mackie Ultra Control with Pro Tools 6.4 livstone Pro Tools TDM Systems (Mac) 2 05-01-2007 11:30 AM
mbox2 drivers for the macpro laptop Tony Eijkelenboom Pro Tools M-Powered (Mac) 1 09-17-2006 07:06 PM
I am setting up my laptop G4 surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-11-2003 11:22 AM
