Old 10-09-2016, 10:49 AM
conleec conleec is offline
Default Cannot Edit Clip Effects in PT 12.6 HD
Hello everyone,
I just installed PT 12.6 HD and am playing with the new clip effects. The problem is that I cannot adjust anything. Well, to be specific, I can enable / disable the EQ, Filters and Dynamics session, and I can adjust the HP and LP filters and the LF node in the EQ. I cannot grab and/or adjust ANYTHING ELSE. Am I missing something?
Chris Conlee
Old 10-09-2016, 11:10 AM
Default Re: Cannot Edit Clip Effects in PT 12.6 HD
Update: I just restarted Pro Tools and I'm now able to edit clip effect parameters. Maybe just a glitch in the Matrix?
Chris
Old 10-09-2016, 11:35 AM
Update 2: After about a half hour, the clip effect editor has become "stuck" again, with only one or two parameters being selectable. Everything else cannot be manipulated. Anybody else seeing this?
Chris
Old 10-09-2016, 03:40 PM
Carl Lie Carl Lie is offline
This has been an issue with me. I hope now that a few have reported this that Avid will take note.
It can happen if the clips are grouped but mine are not. Are you using HDx or Native?
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 10-09-2016, 04:15 PM
I'm a CPTK refugee, running HD software only. 12.6 has actually been running very well for me today, outside of this annoying bug. Particularly since I can make great use of the clip effects on the current project I'm working in. Sucks to have to restart every time I want to tweak a clip...
Chris
Old 10-11-2016, 11:57 AM
pjkmusic pjkmusic is offline
This same thing is happening to me. Clip Effects are pretty much useless right now.
Old 10-11-2016, 12:00 PM
Drew Mazurek's Avatar
Call me Captain Obvious if you must but....
Making sure everyone knows that Clip FX are only editable when the clip is fully selected.
*ducking*
www.drewmazurek.com
Old 10-11-2016, 12:16 PM
Is there a way to "partially" select a clip? Not being a wise guy, just not sure I understand. I'm pretty sure I've got the clip selected when I'm unable to modify clip effect parameters.
Chris
Old 10-11-2016, 12:19 PM
Chris
Sure, with the selector tool. Also, I wanted to make sure people weren't thinking they should see the settings simply when the cursor is placed on a clip.
Just trying to cover all bases.
www.drewmazurek.com
Old 10-11-2016, 12:49 PM
Well I'm a picture guy, who's doing audio on a labor of love project. I will be the first to admit I'm no expert at Pro Tools. Media Composer yes, PT no. Here's what I'm doing. I use the "arrow" thingy to select the clip I want to apply a clip effect to. Then I click on the clip effect editor button. If I've recently restarted Pro Tools, this results in me being able to adjust parameters as I would expect. But if Pro Tools has been running for a while, then this very same sequence of events will result in me not being able to adjust most of the parametes in the clip effect editor. Feels very much like a bug to me.
Chris
Clip Effects Freezing Carl Lie Pro Tools 12 3 10-05-2016 04:24 AM
Clip Effects - Compression Metering?? off the wall Pro Tools 12 8 09-30-2016 09:59 AM
Clip Effects Enabled by default cshaw Pro Tools 12 0 09-30-2016 08:52 AM
Clip effects not working [SOLVED] cshaw Pro Tools 12 5 09-30-2016 05:22 AM
Issue dropping more than one clip into the Edit Window with Clip Transparency ON arb232 Pro Tools 12 0 02-10-2016 06:01 PM
