#51
Re: EUCON 3.0 and system 5-MC
I was about to try installing 3.0.1 tomorrow but I think I will wait until this issue is solved.
Thank you Roland. H.G. It's good to hear from you again. It's been a while... Do you know if someone from avid can test the system 5 MC with 3.0.1? I think we deserve this. It's been a few months since the PT 11 release. Thank you and regards,
Serge Hamel Mixer / Sound Designer http://www.netpostproduction.com http://immersivesoundvr.com/ |
#52
So, 26 days and still no answers.
Can we please have a confirmation from you H.G.? Can we go back and forth between PT10 and PT11 with the system 5 MC ? Any serious bugs? I would like to make a new attempt to install eucon 3.01 today. Thanks.
#53
Yes, S5MC works with both PT11 & PT10. As mentioned in an earlier post, you must copy & rename your custom appsets if you want to carry them across from one version to another.
You should be able to email me directly by clicking on my name (above). Alternately, phone support can be reached at 1-650-237-1604 There should be another EUCON release, which provides additional stability, in the near future. |
#54
I did the installation yesterday. Apart from a few little bugs, it seems to work fine.
I'm glad I can finally split the work load between PT10 and PT11. Great thanks H.G.
#55
It's been a week and the system 5 MC and Eucon 3.0.1 combo seems to work fine with both PT10 and PT11.
#56
No problem so far on 3.1 either
#57
Italked too fast.
In protools 10, same problem as in 3.0 Nice one ! no info passing from protools to the 5MC …. no meter, no automation |
#58
Roll,
Did Pt 10 stop working with Eucon 3.0.1 and System 5 MC or did PT 10 ever worked? I 've conformed and remixed few episodes (created in PT 10) in both PT 10 and PT 11 for two weeks and have not encountered any major problem. I did have some problems with the 408T modules not updating when installing eucon 3.0.1. But the 408T updated well after a second eucon 3.0.1 installation attempt.
#59
3.0 Didn't work
3.0.1 work well 3.1 , same as 3.0, no automation, no meter |
#60
I haven't installed 3.1 yet. I thought it was only for the artist series...
Eucon Windows BUG: some windows r stuck in background when Eucon running. | TuckerMix | Artist Series | 12 | 07-08-2014 01:37 PM |
EUCON 2_6_1 eucon discovery cant find ip | klaukholm | System 5 | 2 | 10-22-2011 12:01 PM |
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon | DigiTechSupt | Artist Series | 11 | 02-24-2011 10:25 PM |
EuCon 2.5.6 with non-PT DAW? | surroundsfx | Artist Series | 3 | 11-29-2010 12:52 PM |
