#41
Re: EUCON 3.0 and system 5-MC
Now I 'm really confused. The system 5 MC link is now working and isn't forwarded to the S6 anymore.
http://www.avid.com/US/products/System-5MC Avid, would be possible to clarify the future of the system 5 MC and MC Pro if possible? Thanks!
Serge Hamel Mixer / Sound Designer http://www.netpostproduction.com http://immersivesoundvr.com/ |
#42
http://www.avid.com/US/products/MC-Pro "MC Pro MC Pro is no longer available and has been replaced by the new Avid S6, a brand new breed of scalable, modular, EUCON-enabled control surface that enables you to mix Pro Tools and other music and audio post DAW projects faster and easier. For details about this exciting new customizable control surface, visit the Avid S6 page." The m5c cannot exist without the pro, so unless they are coming out with a new Pro replacement, we are out of luck |
#43
Out of luck and out of comment from Avid.
#44
Ok,
i made the jump to eucon 3.0.1 Everything is perfect on protools 10.3.7. At least a good news ! |
#45
That is good news Roll.
Are you able to work in both PT 10 and PT 11 without any problem? Does PT 11 recognize all user sets soft keys from PT 10? I guess you made some tests opening both old PT 10 sessions and also creating new ones? Thanks.
#46
I did not make a long test on protools 11, but it worked well for the 20 minutes i used it.
In protools 10 everything is smooth. Just created a new session without problem, opened an old one without any too. Roland |
#47
Thanks for the update Roll.
I think I will wait another 2 weeks before attempting to install Eucon 3.0.1. I can't afford to loose a day. So, just to be sure...Does PT 11 recognize all user sets soft keys from PT 10? Thank you.
#48
So let me ask the same question again. Does PT 11 recognize all user sets from PT 10?
I asked this question at the AES and the answer was, "It should work". Can anybody from Avid chime in? Did you try it? I don't mind renaming my user sets to PT11, but I really need to know if I can use my user sets in PT11. Thank you.
#49
They will not be automatically recognized, but you can copy the PT10 app sets and rename them so that they will work in PT11.
The files need to be renamed to: Pro Tools 11Mac.xml for Mac or Pro Tools 11PC.xml for PC. The spacing is very important. You must name the files exactly as above!! There may be some commands that will not work, and any new PT11 commands will not be there (like meter commands). If you're up for a challenge, you may be able to use an XML editor on the files to customize them further. |
#50
Sorry,
i didn't have the time to test it. Some issue again, i lost one time a day the link with my faders pack. I will try to erase the mc pro and make a clean install. Who knows Roland |
Eucon Windows BUG: some windows r stuck in background when Eucon running. | TuckerMix | Artist Series | 12 | 07-08-2014 01:37 PM |
EUCON 2_6_1 eucon discovery cant find ip | klaukholm | System 5 | 2 | 10-22-2011 12:01 PM |
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon | DigiTechSupt | Artist Series | 11 | 02-24-2011 10:25 PM |
EuCon 2.5.6 with non-PT DAW? | surroundsfx | Artist Series | 3 | 11-29-2010 12:52 PM |
